Winter tire help.
Winter tire help.
Hey guys i need your quick input. Im looking to get some inexpensive winter tires for my s type 2000 4.0. I have 17 inch rims for her and am goingto pick up some 16s for winter.
My question is. The stock 16 inch tire is a 225/55/16. But this is a tough size to find. The guy at bridgestone told me that a 215/60/16 would work just as well as a substitute for the 225. I was wondering what your guys opinion is on this. Would the 215 work fine? Thanks so much. I look forward to your input.
Received 2,263 Likes
I'm from WI and I can tell you that most vehicles you find in the ditch are 4WD/AWD. It instills a false since of security because you can accelerate better. My advice is... spinning aint winning, it's just fun. This goes for racing and for driving on snow and ice.
4WD won’t stop you from going into a ditch, but it MIGHT help you get out of a ditch.
RWD is just fine as long as you TAKE YOUR TIME.
215 would work well, just as others indicated. I like Hankook Icebear W300's myself. Pretty reasonably priced, are not a super knobby winter tire so you still get a fairly smooth and quiet ride, and the compounds work very well on the ice. If your area tends to get a lot of snow and you often drive on unplowed roads however, you may want a tire with a bit more of a biting design and give up some ride and handling in exchange for traction.
215/60 will not work well as this diameter is bigger, and in the event of using snow chains, you're in trouble
Better go for 215/55-16 if you want to fit chains
215/60 is a 2% increase in circumverential size and a total hight of 654 mm's
215/55 is a 1,7% decrease and a total hight of 643 mm's
Thanks all,
Jochem, the issue of using snow chains is not a problem. I do not believe we are able to use them in most locations. Although we are allowed to use studs in the tires.
The advice about driving is great. I am a pretty cautious driver and prefer not to drive when the weather is not up to par and the roads arent cleared, sanded, salted. Thanks
James007
09-06-2015 06:47 PM
