Wiper Arm - 2003 S-Type (Fixed)
I have a wiper arm on the passenger side that tries very hard to wipe the windshield but it only moves about 3 inches. Since its trying to move can I assume its not the motor and that the arm is stripped and I just need a new arm? If so, where would you recommend buying a wiper arm online? I called my local dealer which is 2 hrs away and they can order one in for $40.00..
Thanks for your time.
Antonio
Antonio
Received 6,312 Likes
tferraro (03-14-2012)
Thanks!
There may or may not be a plastic plug on the top of the arm mounting, pop it off and you will find an M10 nut (13mm spanner/socket) take that off then you can use a puller or a lever to get the arm of the spindle taper, hopefully you will find something loose here and the linkage will be in good shape.
neruda
10-18-2015 01:19 PM
OkieTim
09-08-2015 04:48 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
