Wiper arm, driver side
Wiper arm, driver side bends in the middle when it sweeps. Tried two new blades still doesn't clear unless someone applies pressure to the center during the sweep? I was going to order the arm p/n XR852224 at a local Jag dealer and thy said that the arm supersedes up to a another p/n that costs more.
New to this awesome Forum - Please help
Received 2,652 Likes
3434char (03-10-2016)
I have other questions that I'd like to put on this post regarding my new first time JAG.
Rear right, passenger window will not move with either switch? Any DIY's on the forum to help me trouble shoot which switch is bad?
fuel cover latch doesn't work . would that be a solenoid or a fuse?
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Ya, look around on this site there be lots'o good info here.
It may take you a little while, do don't be upset, work your issues one by one.
Owning an S-Type is a commitment, don't rush you'll only become frustrated.
Jaguar - it's not an automobile, it's a Motorcar
Current Hers: '13 Lexus ES350
Current Mine: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past Ours: '05 X-Type 3.0/auto Jaguar Racing Green
Hello pab,
I wanted to know if anyone here can look at some pics of the driver wiper arm. It has a Trico #165951, which wondered if that's right since I thought it would have an OEM # on it? I also have a shot the where arm is hitting the underside of the hood. I bought a arm remover tool, loosened the nut, removed the arm and then tightened the nut. It still is hitting the hood when it goes under?
Sorry, can't help you have a 4.0 car and they are very different from the post face-lift cars.
If you remove both wiper arms, you must notice there is a difference between the LH and RH arms on LHD vehicles. If the dealer gave you the part number of XR852224 as the superseded number for the LH (driver's side) arm, that is incorrect. The correct part number for the LH arm is XR852222.
They are not interchangeable.
3434char (03-21-2016)
Hello NBCat,
Thank you for the reply. I tried to attach pictures of the driver blade, still learning how.
On the underside of the driver arm it has a TRICO 165951 AAX D/SIDE
The dealer gave me the XR852222 and said it replaces the XR827870. I researched the new part and it comes with a washer tube attached?
Hello NBCat,
Be sure the wiper motor is parked in the correct position prior to fitting the arm so it has the correct sweep and then parks in the correct position.
roberthornsey
03-11-2016 08:38 AM
jaggernought
03-04-2016 01:40 PM
