Wiper Arm Removal
Received 6,319 Likes
You should put a towel or similar on the edge of the bonnet/hood for safety, I believe there is a special tool available, people have said also they have used a ball joint splitter and vigourous shaking is also popular. Good luck.
Incidentally it isn't a 13mm nut if it takes a 13mm wrench it will be an 8mm nut.
Not to rain on anyones parade, its a 13 mm nut (I am holding 2 of them in my grimmy little hand as I type) one handed of course!
My procedure was to raise bonnet/hood, CAREFULLY pry the rubber hose off, loosen nut to just above stud, grasp bottom of arm and using a small ballpean hammer have a go or two on the nut. Arm will pop like popcorn!
ClaytonGardens (03-31-2017)
I am indeed, I had to take the arms off last week to replace the pollen filter, and the nuts are 8mm for sure.
I used two open end wrenches to get the arms off one to slip under the arm and around the shaft and another on top to lever the arm off.
The first one just popped off and the second one needed a tap on the end of the spindle to release it.
No nuts were abused in the process.
The unusual thing about the S Type wipers (at least I have never seen it this way on any other car) is the wiper arm has a smooth inside bore where it attaches to the wiper shaft. This slides over the splined shaft that moves the wiper back and forth.
So when you tighten the 13mm nut down you are forcing this spline pattern into the raw smooth Aluminum hole in the wiper arm. This really makes the wiper arm stick on the shaft and can be a SOB to remove.
I never would have found this out except for a weird thing that happened when we had some local flooding. I was driving in the left lane of a 4 lane road as the right lane was under water. A jackass in a big 4 wheel drive truck came blowing up in the flooded right lane. My car was completely covered in the wall of water he was throwing off. Well with the automatic wipers it thought I was in a downpour from Hell!! Of course the wipers came on at full speed but there was just too much water and the splined shaft tore the guts out of the wiper arm hole!! The passenger side wiper just fell to the cowl while the driver’s side kept merrily wiping away!
I ordered a new wiper arm for Jaguar (the price was very reasonable, about $25-$30). When I got it I noticed the internal bore was smooth. Most wiper arms have matching splines and sometime a keyway for alignment. I called the Jaguar dealer and of course they no clue but did check all their stock of wiper arms. Sure enough all of them right and left side were smooth inside.
So when I installed the new wiper arm I had the option of putting the arm on in any position I wanted to. It all went just fine but was much different than I expected! I later removed the arm so I could remove the strut tower brace and it had the splines cut into it just like any wiper arm I have ever seen.
If your wiper arm is stuck and if they have never been off they will be stuck! I use the tool below. No damage to the car or wiper arm.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/86926d1401985498-wiper-arm-removal-wiper-arm.png)
Very cheap at about $5. There may be a better removal tool out there that I don't know about too.
http://www.summitracing.com/parts/rn...FWYV7AodYmsAmw
I'm going to let it site a bit more. I don't see how a puller will work on these oddly formed arms as it's a smooth taper on the back side and doesn't really seem like a puller would be able to get behind anything?
Can't see how that tool would work either?
Yes that tool looks odd until you get it in your hands. The small tang is placed under the bottom edge of the wiper arm hub. The long handle lays back on top of the wiper arm.
Now you have a handle that is pulling up from the bottom of the wiper hub. Exactly where you can't pull using just your hands.
Then rocking back and forth will help wiggle it off.
But mine were tightly seized and I had to work on the drivers side to get it loose.
Sorry I use to post under Tbird6 too. I know confusing.
Thanks. It's been sitting for a couple of days now. I'm currently putting up a sunshade over the car so I can work on it. It's damn hot here in the sun. So I'll try that if my penetrant doesn't work out.
Hi Staatsof
If you have a bearing puller that allows for using only 2 of the 3 arms. Then you can give this method a go. You tighten the nut back on the wiper stud with enough thread to make a dish for the centre arm of the puller to fit on the stud (this will keep it from coming off when tightening it down) then very carefully manipulate the puller so it will grab both sides under the wiper and tighten the puller (as close to) evenly as possible. This is not a perfect solution but I found this worked. It did not take much pressure to lift it and did not damage the wiper. So don't use too much force when tightening the puller down.
Good luck
Paul
Good luck
Paul
Hi Staatsof
Good luck
Paul
Good luck
Paul
Jaguar design brilliance once again.
![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
I'm going to give the lever tool a shot. I guess I can always buy new wiper arms but I'd rather not.
Update: One came off with a 2 ft piece of 1x2 levered against a small block of wood on the windshield. That was the driver's side the easiest to reach. It was the end of the day so I'll try again on the other one tomorrow.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/0707191220a_1__a620f686f51b365d1ed9fcfaab273c6a381c34cc.jpg)
I have all of those tools but don't see how they can work on this style of arm. There is no spot to grip the back of the arm as it smoothly tapers to barely larger than the shaft it slips over.
Jaguar design brilliance once again.![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
But that didn't work on the other side so today I wrapped electrical tape around the tips of my puller and utilized the nut to make sure the puller's shaft didn't wander off of the wiper shaft. It did the first time.
This worked so hooray.
