Wiper Blades
Old 05-06-2012 | 05:59 AM
John Dunn's Avatar
Originally Posted by Zenman63
I have just fitted the later style blades fitted to new cars.
They are in the UK but would post I think.
So much better and comes with the washer jets for the face lift cars.
Link Jaguar S type 2004-Current (WASHER JET FITTING)
These fit with No adapters the are made for the job.
Thanks for the suggestion Zenman. I am new to the forum, having just bought an S Type and you have solved one of my 2 (pretty minor) problems. Cheers,
John
  #62
Old 05-07-2012 | 02:17 PM
Docuzzie's Avatar
Default Wiper Blades Replacements
Originally Posted by s type R JAG
I have searched high and low, but cannot figure out how to take off the old wiper blades on my 05 STR to save my life. The nozzles are on them and makes it virtually impossible, I am in dire need of new wipers these are peeling off.. any help please!
You can buy from a Place Called RockAuto Auto Parts (Found out about this place at the Jaguar and Corvette show many of the forum members attended last year up in Pittsburg PA) replacement rubber and blades which are manufactured by TRICO wiper and blades that will fit the 2005 Jaguar S-Type R. I purchased some and keep a spare set in the garage in case of emergencies. I'm posting the part number and price of the ones I purchased from their web site and they're a perfect fit for the 2005 with it's funky wiper assembly
TRICO Part # 15190 Teflon Blade; 19" (480mm) 7mm Bayonet, 2-Screw Bayonet, 7/9mm Hook Type, 3/16" Side Lock, Pin Type Side Lock
Use original adaptor and wet arm clip.; Right $8.38
TRICO Part # 15240 Teflon Blade; 24" (600mm) 9mm Hook Type, 9x4 Hook Type, 1/4" Side Lock
Use original adaptor and wet arm clip.; Left $10.23
This is directly from their website. The cost is less than the replacement rubbers from Jaguar also.
The following 2 users liked this post by Docuzzie:
Staatsof (05-08-2012), The Chris X (05-08-2012)
  #63
Old 05-07-2012 | 02:48 PM
Bacardi 151's Avatar
Shameless plug, I'm selling brand new, unused UK blade-type 05+ wipers for $40 shipped to the US...
Here's a pic and my ad in the for sale section...
https://www.jaguarforums.com/forum/p...-nozzle-64422/
  #64
Old 05-07-2012 | 10:18 PM
Tboneguy's Avatar
PM sent
  #65
Old 05-07-2012 | 10:54 PM
Originally Posted by Tboneguy
PM sent
PM returned...
  #66
Old 05-08-2012 | 08:01 AM
Jon89's Avatar
I've always been able to find the Trico insert refill blades at my local NAPA for about $5 each. Sometimes they have them in stock, sometimes they have to order them for next-day arrival. I typically replace them once a year just before the car is due for its annual state inspection. Most inspection shops here will fail your blades if they show even the slightest amount of wear-and-tear....
  #67
Old 05-08-2012 | 08:23 PM
Staatsof's Avatar
You can't even order them on-line anymore.
Most local stores near me don't have them in their computer inventory but I went to the store and they had them.
I suspect that these are going away soon. At least at Napa.
  #68
Old 05-09-2012 | 08:56 AM
Jon89's Avatar
Sure hope they don't disappear at NAPA. Nothing else comes close from a cost-effective wiper blade refill perspective. To be on the safe side, I'll probably buy multiple sets next time I set foot in my local NAPA store....
  #69
Old 05-20-2012 | 03:19 AM
HIJag's Avatar
Originally Posted by vance580
I wish they sold refills in the stores like they used to at least around here. If I want just the refills I have to get them off the internet. I usually just replace the whole blade which is why I alway just take the whole arm off. Its just so much easier and dont risk messing anything up like scratching the hood. If I was to get refills I'd probably do those with the arms still attached.
Is there some trick to getting the wiper arm off the shaft? I removed the retaining nut, but I can't seem to get the arm off the shaft. I don't want to force anything. Thanks.
  #70
Old 05-20-2012 | 06:16 AM
Staatsof's Avatar
I haven't done that so I can't help you there. But as this thread is about wiper "blades" I have to ask what is your reason for changing the arms?
  #71
Old 05-20-2012 | 10:50 AM
The arms are fixed on a tapered spline. You can get a special puller to get them off or you can use a lever of some sort under the arm, keep the nut on a couple of threads so the arm doesn't fly off and take care not to damage anyting with your lever.
  #72
Old 06-10-2012 | 01:26 AM
dlnga's Avatar
Default Replacement wipers 2005 STR
For the passenger side 19'' blade...Advance Auto-Trico 22'' "Break to Fit" $7.00
For the drivers side 24'' blade..No longer available BUT can purchase Trico 24'' "Exact Fit" assembly also at Advance Auto for $12.98 and take the blade out and put it in the original wiper assembly...easy breezy and done...
  #73
Old 06-10-2012 | 01:32 AM
dlnga's Avatar
Advance Auto-Trico 22'' Break to Fit $7.00 Passenger
Advance Auto Trico 24'' Exact Fit Wiper Assembly $!2.98
just pull the blade out of assembly and insert into original arm on Jaguar...
  #74
Old 12-17-2012 | 05:42 PM
devo357's Avatar
Oh Gawd I just bought a set of RainX! wish I would have read this post first.
My car came with what looks like one piece goodyear wipers which I was able to get off I just disconnected the the feed tube to the nozzle. The RainX fits tight at the hook end so I will have to break out the dremel tool and grind out the inside. The guy at the parts store told me for the 07' S type they are 19" and 24".
With that said they seem to be working pretty damn good a lot better than the ones that were on there before but I am concerned about the stiffness at the hook end.
  #75
Old 12-18-2012 | 03:34 PM
devo357's Avatar
Just called the dealer $24.00 for the drivers side
kingdom worker
11-14-2020 04:47 PM
Ferdie
11-26-2018 06:42 AM
davidboger
10-01-2015 11:13 AM
