Wiring diagram for standard radio for 2003
Hello
I want to connect my parrot mki9100 to my 2003 3.0 sports standard radio. I am unable to find a wiring diagram in my manual. I need a permanent power supply (battery) I thought I would use the power supply to the radio.
A connection to the ignition (this would be the power to radio when turned on)
And finally ground.
Can anybody send me a wiring diagram or tell me which colour the cables are that I should use on the cars power supply to the radio.
Thank you for your help.
Ducmon
And finally ground.
Ducmon
I have found this on the internet.
Can anybody confirm it for me please.
2003 Jaguar S-Type Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Ducmon
Ducmon
Received 6,307 Likes
If you are meaning section 415 (information and entertainment systems) i can not find any information about the pins or colour of the power and earth cables and I have looked in 418-02 (wiring harness) as well.
Am I missing something and is there another section that I should go too?
ok this seems to be where I am getting confused I have been using a downloaded workshop manual for 2002.5 to 2008 and not the jtis.
I will look there later.
Thank you for your Patience with me. I have always found the wiring diagram at the back of the workshop manual for every other car and motorbike that I have worked on.
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
Ahh, in that case you can get them e.g. JagRepair.com - Jaguar Repair Information Resource
Worth getting the DTC (codes) PDFs too
Ducmon (07-14-2016)
jaguarVP96
04-22-2016 02:21 AM
