Wiring DRL's, lights live all the time
Received 6,330 Likes
I spliced into the orange/yellow and black/yellow wires on the plug for the side lights - but they were on all the time ![Icon Saywhat](https://www.jaguarforums.com/forum/images/smilies/icon_saywhat.gif)
Looking at You tube I found instructions for DRL kits and found you use a spare connection in the fuse box which is live when the ign switch is in position II. I done this and fitted an earth wire attached to a small crocodile clip connected to a bolt in the bay - so that I can easily disconnect them off if I wish.
A bit Heath Robinson but they now go on and off with the ignition![Icon Cool](https://www.jaguarforums.com/forum/images/smilies/icon_cool.gif)
The sills are fine as is the rest of the car, the only small spot of rust is on the front of the bonnet. I'll have to fix it with some touch up paint before the bad weather
![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
Received 9,011 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/168808d1501281146-wiring-drls-lights-live-all-time-car01.jpg)
The sills are fine as is the rest of the car, the only small spot of rust is on the front of the bonnet. I'll have to fix it with some touch up paint before the bad weather![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
You didn't post any pics of the install......if you have em post em on up
I guess I am a bit confused?? You should be able to get the DRL's turned on by the dealer with a change in programming. The S Type was sold all over the world and some places require DRL's.
I know on my wife's 2003 Lincoln LS the dealer can enable or disable the DRL's.
Anybody know for sure on the S Type? Maybe Brutal??
Robinb (06-20-2016)
Mind sharing which fuse this is?
Mind sharing which fuse was this?
Sonspit (07-05-2014)
JagV8 did you ever figure out the empty fuse that would turn on with the ingnition. I need to get some type of lights that come on (DRL) for an inspection to import my car & looking for the easiest way and something cheaper than having to pay a dealer to enable the DRL function.
![Name: d51ddcac-3b60-4ca4-898b-9e3606576809.png
Size: 35.0 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/101223d1416748232-wiring-drls-lights-live-all-time-d51ddcac-3b60-4ca4-898b-9e3606576809.png)
Thanks for the offer six rotors, unfortunately Whitby is a bit of a trip so I just installed some cheap LED strip lights and wire them into a fuse that comes on when key is turned (i.e.) cig lighter.
Funny part is I tried tapping every fuse in the engine compartment and a bunch of fuses in the passenger and it seemed they were all powered even when no key in the ignition so lights would be on all the time - even the accessory/cig lighter fuse was like this at the fuse panel ????
The only place I could get power just whhen key was turned was the actual cig/ lighter port so I just ended up rigging up the power end of the LED lights to one of those splitters you plug into the cig. lighter.
Works for what I need right now to pass RIV import inspection and since I leave the lights on auto all the time anyways it will in effect have Daytime running lights on even if I pull the LED strips I have in there now.
Received 1,442 Likes
Hi fellas,
Please don't misread what I am about to say as any form of criticism or put-down . . . none intended. BUT; I am continually amazed at . . .
But, in the return ground path, no longer is there an internal connection so bolting to metal car body completes circuit back to battery. Now, attachment may be to non conductive plastic, so a second independent wire carries the "ground seeking" side of the device, and here is where you will find your switches, relays, and connections to all the Control Modules. My late S-Type Luxury has 18 of these control modules.
This means that if you go searching with an old fashioned light probe or even a modern DVM, clipped with its little croc clip to a good ground, you will find yourself surrounded by +12V everywhere you turn . . . eg not just one side but BOTH sides of the auto interlock solenoid.
Now, every system thrives on exceptions, so take care around Starter Solenoids & Motors, Alternators and their charge circuits; and also some TBs on some Jags (some XK8s, but I think S-Types are OK). With this brief lesson on board, anyone who goes prodding around the AirBag circuitry with a grounded probe and battery still connected . . . is in for the granddaddy of surprises . . . a modest change of clothes dry-cleaning bill . . . and a really off-putting bill for brand new AirBags.
At the expense of being even more long-winded this gives us 6 magic problem solving tools . . .
If, having done so, there are bits you don't understand then, sure, fire away. You want to connect some new gizmo? Fine . . . follow Jaguar's convention . . . connect one side of your device to +12V power via the appropriate fuse (either permanently on, accessory on, or ignition on) then provide a user override switch . . . whether that's an electronic switch, relay, nice under-dash toggle, or our original friend's croccy clip.
Best wishes, and I'm sorry if I sound a grumpy old sod,![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
- extent of universal misunderstanding or complete ignorance of how modern electrical/electronic systems are designed to operate and
- repeated failure of people to follow repeated . . . and repeated . . . and repeated advice by our gurus (again by JagV8 here) to download, then use, the appropriate Wiring Diagram.
- if a "hot" wire chaffs on the metal body, FUSE WILL BLOW and DEVICE WILL NOT TURN ON;
- if a "ground return" wire chaffs on metal body, FUSE WILL BE OK but DEVICE WILL NOT TURN OFF;
- if either wire breaks, FUSE WILL BE OK but device will NEVER TURN ON;
- from 3; if wire or connector is open in "hot" lead, NO +12V WILL BE DETECTED IN EITHER LEAD;
- from 3; if +12V DETECTED IN BOTH LEADS, then any fault lies in the "ground seeking" path or control devices;
- from 3; if +12V DETECTED IN ONLY ONE LEAD, then the device has failed and should be replaced.
Ken
Jumpin' Jag Flash (11-28-2014)
The following 2 users liked this post by JagV8:
cat_as_trophy (11-27-2014),
Jumpin' Jag Flash (12-18-2014)
