At Wits End - P2135 TPS Code - Remanufactured Throttle Body
Hi folks,
I've got a 2005 S-Type with 93,000 miles on it. About a year now I've been having Throttle Body issues. I've cleaned all of the contacts, replaced the battery, everything. I bought a remanufactures Throttle Body from ASI in Tenessee. The first one I got installed threw the fault code the second I got the key to position 2. I sent it back (Lifetime Warranty) and they sent me a replacement. In the interim, I reinstalled the original, and with the new battery, the issue seemed to resolve. Within the last three days the original started throwing the code and going into limp home mode, so I installed the 2nd remanufactured one. Same scenario, it throws the code the instant I get the ignition into position 2. The car will start, but stays in limp home mode.
I have tried to reset the ECU by disconnecting the battery negative and holding to the connected positive for 30 seconds. The battery was disconnected during the switchout, which took about 45 minutes.
Is there anything I'm missing? It's strange, although certainly not impossible that I'd have gotten two faulty units in a row from ASI.
I'm just wondering if there is any step that I'm missing to get the car "used" to a different Throttle Body assembly.
One more thing, the vehicle only goes into limp home mode when coasting at low RPM. Less than 2000, but never at idle. At least that's the situation with the original T/B.
Any help would be greatly appreciated.
Thanks!
Scott
Thanks!
Scott
Scott Taylor (04-08-2014)
That bulletin [JTB00022] is ONLY for the 2006 and later PAN-PAG engine management system. Up to 2005 used the 32-bit ECM system. P2135 meant entirely different things 2005 vs 2006.
2003-2005: P2135 = Throttle Position related fault, meaning throttle body
2006-2008: P2135 = Pedal Position Sensor related.
This is why it ALWAYS has to be known what model year and engine system is being discussed. Otherwise you go off in the wrong direction; possibly in an expensive way.
The OP needs to have some competent circuit diagnosis done to get to the bottom of his issue; especially given the throttle body has been substituted to no avail.
Cheers,
Cheers,
JagV8,
The battery was disconnected during the swap. In addition, I left the battery disconnected for 36 hours after the initial error code (P2135).
I reconnected yesterday and the error re appeared when I moved the ignition switch to position II, even before I started the engine.
I did use an OBD2 device to clear the codes, but they instantly reappear.
Scott
Scott
You are saying “codes” And in my first post and this one I am asking for ALL the codes that you captured. Using all the codes should help in narrowing down the problem.
JagV8,
Scott
Scott
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi All,
I have an 05 Jag STR that went into limp home mode, DSC fault, Park Brake Fault, etc. Took into dealer on Saturday, got back to me today and voila, says needs new Throttle Body, threw code 2135.
What are my other options. Looked at Technical Bulletin and I don't think mine applies as it's an 05 (Brembo's). My husband is a very well versed mechanic and we have a lift in our home, so it's worth a shot.
SNG Barratt USA (05-05-2014)
