Won't crank first Jaguar need help
I have read about every thread about no crank, battery issues, grounding straps, fuses.
Problem is car will not crank. I can hear the solenoid on the start click but it will not turn the car over. Has a new battery with about 12.4v. Battery is new 900cca battery. I check all the fuses in the boot and the engine, all ok. Are there any other places where fuses are located? I've tried the +/- terminal reset then reconnected the battery. Put the key in the door and lock an unlock the door. The shifter has a red P. When in N the solenoid clicks. When in D it doesn't click. So that leaves out the trans position. All the lights work but the RH signal lights. Radio works and comes on when you reconnect the battery.
There is a little dome looking thing on top of the dash in the center. It lights up red and goes off. On either side of the odometer there is a yellow and red light. What is that for? The only message that comes across is a DCS fault.
I thought about removing the start. But can't get to the top blot. How in the world do you get the starter off? Someone really needs to make a YouTube vid of this..
I am in the dog house on this car. If I can't get this thing to turn over my wife is going to kill me.
Have you looked at your starter relay? Look at the oneline Fig 02.1
Link http://jagrepair.com/images/AutoRepa...01999.25en.pdf
joycesjag (11-08-2015)
Look at the first few pages it gives you the location of fuse boxes, relays and control modules.
Gus
www.jagrepair.com
Gus
www.jagrepair.com
As was posted above. Put your head lights on and try to start the car.
Do the head lights dim? Heavy amp draw. Remove the starter and check it out.
Lights do not dim. Different problem. You are not getting power to the starter. Check the relay as posted above and look at cables and connections.
Maybe corrosion has followed the copper back inside the insulation and you need some new cables?
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
Update;
We'll have done a lot of work on the Jag. Had removed all o the interior, carpet, seats etc. Dry out the car. Was able to remove the starter. Found a S wrench from harbor freight that got to the back bolt. Starter was toast. Replaced the starter and crank and stop. After removing the spark plugs found out cylinders 1 and 3 don't move. Seems the rod has come off the crank. You can turn it over by hand until you get to a certain spot. Going to drop the pan to look and see for sure. Now I am trying to find out what to do next. I am trying to sell the car for $1300 or best offer. Body is straight. I need to get rid of this. I have gotten sick and do to health reasons don't have the time to deal with this right now. So if any one knows someone who's looking for a good project car.
AndyZ
11-23-2015 04:55 PM
