Wow! Hotness
Guest
Posts: n/a
Hey, guys new to the forum and already having an issue. I just replaced the rear brake pads in my 2003 S-Type and They feel better, stop softer, no functional problems or noise.After a 15 min drive the brakes are hot, stink, and smoke a bit... Is this normal or could I have messed something up?
Thanks for the help!
Received 6,320 Likes
Try this -
Electronic Park Brake (EPB) –
Re-Calibration Procedure
2003 MY-ON
S-TYPE
M44998-ON
Issue:
On some 2003 MY-on S-TYPE vehicles, a customer may report a concern of premature
parking brake pad wear or the brakes binding. This condition can result if the electronic
park brake (EPB) system is not re-calibrated after the removal of the rear brake calipers
to replace the brake pads.
Action:
Should a customer express concern regarding the above, refer to the calibration
procedure detailed in this bulletin.
1. Reset the EPB module:
a. Switch off the ignition.
b. Disconnect the battery for 30 seconds. For additional information, refer to STYPE
Workshop Manual Section 414-01.
c. Reconnect the battery.
2. Start the engine.
3. Firmly apply and release the footbrake five times.
4. Confirm that the message ‘NOT CALIBRATED’ or ‘APPLY FOOT AND PARK
BRAKE’ is displayed on the instrument cluster message center. This indicates that
the parking brake is in calibration mode.
5. Lightly press the footbrake pedal.
6. Apply the parking brake by using the EPB switch.
7. Release the parking brake.
8. Release the footbrake.
9. Confirm that the brake warning lamp is no longer illuminated on the instrument
pack and that the ‘NOT CALIBRATED’ message is no longer displayed in the
message center.
10. Apply and release the EPB five times to ensure no error is present.
2003 MY-ON
S-TYPE
M44998-ON
Issue:
Action:
message center.
Guest
Posts: n/a
dmatthewman
09-30-2015 10:10 AM
