Yet another p1584 code
Old 09-30-2014, 08:30 AM
KevinVinke's Avatar
Default Yet another p1584 code Now with veichle details oops
Hi all,
Id appreciate comments on the following.
Jaguar 2001 S-Type 3.0 V6
The only code showing is p1584
On ignition position 2 I have:
MIL light on
Low Washer fluid (ok I know that one lol)
Gearbox Fault.... yes the TFT sensor is broken no code though
Engine Failsafe mode
On Start up revs come down normaly 750 rpm and the cooling fan goes to max.
STFT and LTFT on both banks +- 3 max usual 1.6 fluctuating.
TPS shows 11%-79% throttle range
O2 sensors pre cat fluctuating v after cat steady .8v
On driving car drives normaly, sport mode works and cruise control works. If it was having issues with controlling the TB surely it wouldnt allow cruise control?
Anyway thanks for reading!
cheers Kevin
Old 10-02-2014, 03:10 AM
KevinVinke's Avatar
ok so Ive taken a punt on used throttle body (€122) which the seller is garaunteeing for 12 months. Will see what that brings.
Old 10-03-2014, 02:45 PM
tbird6's Avatar
I don't know what a TFT is? Can you explain?
If your used TB does not work I would send my original in to be rebuilt. That way you know it's the correct one.
Old 10-03-2014, 03:52 PM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Trans Fluid Temp, I expect.
aka TOT Trans Oil Temp
Old 10-06-2014, 03:35 AM
KevinVinke's Avatar
Thats the one :-)
Old 10-10-2014, 02:08 AM
KevinVinke's Avatar
Just a quick update. Received the 2nd hand throttle body and fitted it. P1584 is now gone as have the other faults, except of course the Gearbox light.
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
Terry H
07-04-2017 05:48 PM
JCam
10-23-2016 08:27 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: Yet another p1584 code
