Zenon turned pink.
RE: Zenon turned pink.
I'm having trouble finding the HID modules. There are so many fuses and relays that relate to them in the owners manual that I'm not shure which is which. I did swap the R10 and the R13 micro relays but no difference.
Also Genius I would be interested in the bulbs and or the modules. I sent you an email reguarding prices.
Thanks.
Thanks.
Let's see if this helps. They are both the same white when they first come on but after a few seconds the drivers side starts to turn a purplish ntil it gets fairly dark and then stays.
BTW. I found these on ebay. The seller claims that they are direct replacement for my bulbs. Haas anybody ever tried them?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170213252815
Genius, I'm assuming that yours are new? Both bulbs and modules.
Thanks.
Thanks.
yeha bulbs are new.. modules are new just not in there boxes.. but i can get new ones in boxes for the same prices.. plus bulbs
and those are the bulbs they llok exactly like the ones jag has.. for 49.00 cant relly go wrong.. but to tell you the truth once you replace one side.. they wont match.. wwe usually replace both at the same time.. so get two bulbs..
mojo, I would much rather put these Philips brand bulbs in your projectors than those aftermarket ones. I fully trust OSRAM and Philips bulbs. you're call bud
If J-genius can get you OSRAMS for less than $150, I would definately go with those. I have a feeler that they will be considerably higher.
Actually that price is for 2 bulbs and I have a shop that will install both for 40.00 so for that price if I am not happy with them I will change them. Also I can give you guy's some feedback on how they work! Genius thanks for confirming that they are the same bulbs and for all your help. Who knows, I may still need the modules after all. I'll keep you posted. Also I am told by my Jaguar dealer that they are about twice the power of stock. Lifetime warranty too so will see. My dealer wanted 319.00 for one bulb plus installation. I'd be looking at about 850.00 for the 2 installed.
By the way, Is there any real trick to installing these bulbs as far as accessing them? Just curious.
Thanks.
Thanks.
wait till you change the bulbs.. warranty time pays 1.3 hours.. your sappose to pull off the bumper to replace... but.. sometimes i do it without.. but the setup is stupid.. you will see. take a pic before remove the actual bulb.. for orientation.. you'll know when you there.. just be patient.. can be challenging.. to install properly..
Well on my way home from work it flickered a couple of times and went out completley so I'm assuming now that it is the bulb. Genius, What makes them different from replacing the halogen bulbs as far as getting to them? The owners manual makes it sound pretty simple.
Speaking of benztojag, there is a guy that left negative feedback on the bulb sight with the name fastbenzamg. I'll bet it's him still complaining. LOL
