Zeus wheels will they fit on a 3.0 V6?
They will most probably fit as there is enough clearance to go over the bigger STR brake calipers. They are staggered sizes right? 8" front and 9.5" rear? For a good match, the offset (ET value) should be similar to standard, especially at the front; about 60 mm. These values are stamped on the inside of the wheel. For a 9.5" wide wheel, the standard tyre width is at the bottom end of OK.
JaguarXKR
17
01-13-2024 07:24 PM
magpies
06-27-2019 08:46 AM
