ZF 6HP26 Drained-and-Filled Again This Morning....
Many thanks to Rick (joycesjag) and Wayne (cjd777) for their very kind assistance with my 2005 S-Type's ZF 6HP26 drain-and-fill procedure today at Rick's house. Just like a year ago, my ZF drained about 4 quarts of ATF after removing the drain plug. Rick skillfully pumped the fresh Mercon SP into the pan without a single hand or wrist burn on the hot exhaust pipes. He is truly the Zen Master of the ZF and the only person I trust to get it right on the money. My S-Type now carries about 80% refreshed ATF since we did the first drain-and-fill last November, and that's good enough for me. As long as my car doesn't start showing signs of the dreaded sleeve leak we shouldn't have to mess with this ZF unit again....
We also replaced my two completely-shot rear sway bar links while we had the car up in the air on jack stands....
I thoroughly enjoyed the company of these two valuable forum members, both underneath the car and later at Rick's kitchen table for a great lunch. I wish our physical distances didn't preclude us from being able to get together more often. It is always such a pleasure when we manage to do so....
Thanks again guys, and Happy Halloween....
Glad everything worked out, Jon!
Sounds like you guys had a good time today.
The ZF drain, flush, refill, and check the sleeve is on my long to do list....
Replaced all four of my sway bar links on Sunday, and discovered I need some bushing replacemnts, along with new rotors and pads all around! ( that was my noise I was telling you about)
Jon89 (10-28-2015)
I would do an ATF drain-and-fill and not bother with having your current fluid tested. If you're going to drain some current fluid, you're going to have to top it off afterwards. Might as well do a proper drain-and-fill instead. Time well spent for preserving these ZF units....
Ha, I am not to sure about the "Zen Master", I believe that title goes to fellow member CCC, for if it was not for him, I would have never had the courage to attempt any work on a ZF box.
It was a very pleasant morning and I too had a great time with fellow enthusiasts and friends. The meal afterwards was top notch. Jons wife was thoughtful enough to send a delicious meal that was enjoyed thoroughly by all.
Zenfly, follow Jons advise above and just do the service on the transmission. Over the years the filter/fluid have come down in price where it makes sense. Now especially with the "aftermarket" fluids found that work very well.
Jon89 (10-28-2015)
Received 6,324 Likes
Designeer (01-28-2018)
Oil Capacity stated by the ZF site is
9.4 liters (10 Quarts) + 0.5 liter (0.53 Quarts) for cooling system for
6HP26 / 6HP28
I have read this oil change a few times in several different places and I don't think I've ever heard of anyone using 10qts yet.. Are people changing half their trans fluid leaving the old fluid in the torque converter and cooler?
PG 19...http://www.ukrtrans.biz/files/2010/0...ansmission.pdf
6HP26 / 6HP28
Yes. The only way to get ALL of the old ATF out is to flush the transmission instead of doing a drain-and-fill or a pan drop, but flushing introduces a new set of risks such as dredging up long-settled debris and getting it stuck in the valve bodies. I will not take that risk, some owners will, but it's your call....
The ZF 6HP26 holds 10 litres of ATF when full. Just pulling the drain plug typically gets 4 to 5 litres out of it. Those who have dropped the pan and allowed the car to drain overnight report getting as much as 7 litres out of it. I would be very happy with a 7-litre drain. I was concerned about our initial 4-quart drain-and-fill last November. That's why we did another drain-and-fill yesterday (resulting in the very same 4-quart figure). That's enough replaced ATF now to satisfy me for the duration of the time this car spends in our stable....
ZenFly (10-28-2015)
I'll do that.. I sent a request to Blackstone last night for a free bottle and return kit. It's only $28 and one way or the other will be a testament to how these ZF are doing. The one in my car is doing 100% amazing and is a marvel. I also think the guys above are right in that mine has very likely never been serviced.
I think someone is going to wind up drenched in ATF and allowing far too much to drain out before being able to cap the flow....
I cannot stress enough that you will be much better off to just bite the bullet and change your ATF. Send off a sample of the drained ATF if you wish....
I'm done here....
I'm done here....
