ZF 6HP26 Drained-and-Filled Again This Morning....
#41
#42
#43
I did s search to find what is high temp for the 6HP26 fluid and found it here.. I learned a few more things about this unit like it has carbon friction discs not paper like most.. there is more interesting stuff here
Everything about your ZF 6HP26 transmission issues | BMW Logic7 site
#44
I changed my ZF fluid about 10K miles ago and used the Amsoil Full Synthetic (product code ATLTP-EA). The 2.5 gallon jug was more than enough to do the job and cost a little over $100 (with shipping).
I was not having any tranny problems, but it seems to run a little smoother now and the annoying "clunk" that sometimes occurred seems to be much less frequent (but not totally gone).
#45
My fluid change seems to have settled almost all my issues. The 2-1 shift kick completely disappeared. I still get a mild 3-4 shift slip on really cold mornings before the car warms up. I used Mercon SP. I'm concerned the slip might be a valve body or possible clutch issue, but it rarely happens anymore.
#46
I have to get the car up on a lift and check the connection on both ends for fluid intrusion. Its hard to see into the TCM pin side but I'm going to get my inspection camera in there.
I also will be updating the TCM software with IDS. Of course as soon as it warms up...
#47
I'm struggling with a 3-4 shift issue as well. I did change the fluid and sleeve. My fluid was low initially and wouldn't even engage into 1st gear. I also cleared adaptations and flashed TCM via my WDS but I know there are newer versions of software available via IDS as WDS flash is circa 2006_07. Now she shifts like butter until that 3-4 gear change where I get the gearbox fault.
It feels like a jerking motion and the revs rise up. (Slipping I guess..)
#48
#49
I'm struggling with a 3-4 shift issue as well. I did change the fluid and sleeve. My fluid was low initially and wouldn't even engage into 1st gear. Now she shifts like butter until 3-4 gear change.
#50
#51
#52
#53
#54
I know . . . I'm just as tired of this one as you. Anyway . . . I need to go back in and make sure this fluid change as correct. I believe I've overfilled it on the advice of someone. After revisiting the Jag.TV video and reading the ZF manufacturers PDF I think starting the engine was all I needed after first fill. Running the J shifter through the gears was not in any info I saw and that's what I did. Geez! I've got what smells like AFT smoke at start up, so I think I'm sucking up fluid. Any comments?
#55
jagstuart (05-09-2017)
#56
#57
mea culpa. i thought i'd not clog up the forum with new a repeated posts about the same old $%^&. just thought this was the most appropriate one to latch onto. car was level and on jacks and i put it through the gears with foot on brake, got back underneath, pulled fill plug, used a laser pointing temp gauge and had pan at approx 40C, bolts at 42C and filled to hole, letting any overage out until it stopped and buttoned it up.
#58
One, you need to essentially get the tube you're using to fill the trans case in at a 90 degree angle away from the TCM. I find if you stick the fill tube straight in some fluid will be kicked back out.
Second, the trans is considered "full" when you have a trickle of fluid coming out at 40 deg C. If you had no fluid coming out or you allowed it to drain until none came out it is under filled.
#59
