ZF 6HP26 Transmission max torque
Anyone know what it might be?
I know the Bentley Supersports has the transmission and is pushing 590 ftlbs so it is capable, but I am sure that Bentley has altered the parts inside a bit. AVOS is pushing I think around 500ish hp to the ground (not sure on torque), so it appears these can handle some power, but I wanted to see if anyone had any definitive figures.
Michael Star (04-17-2012)
at 3500 rpm it gives the most torque (original setup) but if you keep the same torque at higher rpm's the kitty will make you happier
maybe you like this calculator: http://www.wentec.com/unipower/calcu...wer_torque.asp
No but what I am thinking is that when you are modding the engine, you will exceed the torque input amount. Let's say that you increase the engine's torque by 10%. That right there is over the max amount specified by the engineers. I just don't want to have to replace a transmission
As I recall, avos mentioned that the 600hp car does break the trans from time to time. Comes with the territory...
Here's a wrinkle for ya!
2012 XKR-S
• A new addition to the XK model line, the XKR‐S sits atop the range as the fastest and most powerful series‐production Jaguar ever
• 550 horsepower
• 502 pound‐feet of torque
• 186 mph top speed
• 0‐60 mph in 4.2 seconds
• Low volume: approximately 100 per year for the US market
• Unique appearance with carbon fiber splitter and spoiler
I'll have to investigate this at some point, when I have time. Five hundred two pound feet.........that's 680 Nm! That's what you call a ponderable.
Cheers,
2012 XKR-S
• 550 horsepower
• 186 mph top speed
Cheers,
2012 XKR-S
• 550 horsepower
• 186 mph top speed
Cheers,
2012 XKR-S
• 550 horsepower
• 186 mph top speed
Cheers,
The XKR-S is the most extreme example yet, it's an upgrade (S model) to an upgrade (R model)...99.99% who see the thing won't know the difference between the R-S, a R and a regular model ($53K less)...At the track a car new from the factory can beat it that's $100K less...In my useless opinion (because I won't ever buy one) they should of make an entirely different car vs an upgrade to an upgrade...
