ZF gearbox faults, root causes & Troubleshooting
With ref to Jim's request for stickies I think
that this should be included:
https://www.bavlogic.com/?p=3738
https://sayyarti.wordpress.com/2015/...ission-issues/
rgrow3446 (03-12-2019)
Everything about your ZF 6HP26, 6HP19, 6HP28 transmission issues | BMW LOGIC7
Interestingly, there is a link for testing out the MOST BUS network too which would also benefit X150 owners.
This should also be added if it isn't already.
Thought I could add a comment here on what I suffered
04 xj8 n/a
(She) cat threw the abs light
10 miles later , cat went into transmission gear faults and basically wouldn't shift out of second gear . Felt incredibly a bit like the trans was toast clanks and squeals and all kinda ****. So I replaced the driver rear abs sensor with a rock auto part and boom , all was perfect again
transmission didn't like what the abs sensor wasn't saying and acted up for it
04 xj8 n/a
rgrow3446 (03-26-2019)
this should definitely be in the s type stickies as well !!!
thanks
04 xj8 n/a
04 xj8 n/a
I fixed my ZF restricted mode on my 2005 s-type 3.0 by changing the plugs (you have to remove the intake manifold to do the right side), cleaning the throttle body, new battery, clearing the codes. Thanks to this forum I found out those were potential causes, and changing those things removed the restricted mode. My car is fixed and runs great! Very happy!
The following 3 users liked this post by 2005stype:
Received 6,311 Likes
Here's two that do work https://www.bavlogic.com/?p=3738
Aren't mods wonderful?
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Don B (06-25-2021)
Just wanted to add that i got all kinds of gearbox faults due to a leak in the intake pipe (after air massflow meter). I thought i had a really bad transmission as it was behaving, but everything went away when i fixed the leak in the intake pipe. This was on an STR 2002.
Might be worth to take a look at that if your transmission is behaving strangly…
S-Type Owner (08-06-2021)
meirion1
03-31-2023 04:10 AM
meirion1
28
04-27-2019 04:44 PM
