Zf trans help with rpm
I have a 2009 XF with a 4.2. I'm posting this in here because we share the same transmission.I noticed that from 2nd to 3rd and from 3rd to 4th my RPMs will increase 3 to 400 while shifting. Is this normal? It seems like it's taking a little bit longer to shift maybe because of the weather. I'm going to have the transmission fluid serviced and filter changed to see if that might be an issue. Has anybody experienced this and if so what did you do to fix it?
Might be low on fluid. Might be clutch packs going nighty nite.
Best bet - check condition and level of trans fluid and ensure all is well there. If low, top off with either LG6 or Mercon SP, nothing else!
Especially the 3 - 4 upshift slip...
That is the E clutch and usually is the first part of the trans to go nighty nite when the case is low on fluid.
Drive at your own risk.
Personally, if you take care of the above and ensure there is enough fluid (and no leaks from trans cooling lines) your gonna be all right!
Use the above as a starting point.
If none of the clutches are "badly" burned you should be ok after the service.
I was recently having an issue with harsh shifts that seemed to get worse over a couple of months. I decided to replace the pan and do a fluid change. I was still having issues with the harsh shifting from 2-1 and 4-3 and 3-4 mostly (2006 S-Type R has about 137,500 miles). I work at a small Mom & Pop used dealership as an Auto Detailer so I'm able to use their lifts etc. I found through research that the Mechatronic sleeve, valve bodies, and the bridge seals will cause this issues a majority of the time. I replaced all these parts, and the trans is shifting amazing. If you decide that the Solenoids need to be replaced, you have to reset driver adaptations on the transmission which requires computer software. I haven't replaced the solenoids at this point and it seems to be working great. Just search Youtube with the ZF 6HP26 trans and some useful stuff will populate. I found the Mechatronics sleeve, valve stems, and bridge seal from eBay for about $35. if you're going to have the trans serviced already, I would have them replace all those parts while the pan is off already to save an extra pan drop and fluid refill.
Best of luck!
Best of luck!
09XFwhippin
03-27-2018 05:22 PM
Jagbuff_UK
26
06-22-2013 10:55 AM
