ZF Transmission Adaptions Drive Cycle clutch A problems, picture
I was able to adapt every clutch except for clutch A. My guess is that maybe it wont set because of my trans problem ( code P0735 ). But maybe I'm doing some thing wrong, any pointers on Clutch A adaption? This is the info I have for the procedure:
11. 'A' Clutch
^ Maintaining constant throttle input and the torque band is within the indicated bar graph range, continue accelerating to 50 mph (80kph), ensuring the transmission upshifts into fifth gear.
^ Lift off the throttle, allowing the vehicle to slow down until fourth gear engages. The next vacant box for 'A' clutch will turn green with a 'tick'.
11. 'A' Clutch
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/38973-zf-transmission-adaptions-drive-cycle-clutch-problems-picture-img_0402_zps124cfb8b.jpg?dateline=1365435471)
I'm not clear how P0735 would interfere with adapting clutch A but some details of P0735 for Ford's use of ZF 6HP26 (probably applies to Jag too) is publicly accessible here http://www.motorcraftservice.com/vdi...f/obdsm505.pdf
BrentGardner
28
04-26-2024 03:08 AM
