ZF transmission oil and sleeve change writeup with pics FAQ
Old 11-10-2010, 07:03 AM
bogart's Avatar
Thanks.
If the weather improves a bit over here that is next weeks job.
  #82
Old 11-10-2010, 07:33 AM
bfsgross's Avatar
Last night, after suffering horrible up and down shifting, an independent Jag tech swapped in fresh trans (used ZF), engine, and differential fluid...Amazing difference!. She shifts beautifully...smooth, no more "Lurch".
  #83
Old 11-10-2010, 07:54 AM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
Any ideas as to what's wrong with the old one?
What will happen to it? (Don't just scrap it.)
  #84
Old 11-10-2010, 08:02 AM
joycesjag's Avatar
Received 1,703 Likes on 1,211 Posts
As I read it Jagv8, just the fluids were changed. I had to read it a couple of times myself.
  #85
Old 11-10-2010, 09:06 AM
androulakis's Avatar
Yeah that's the impression I got too, that the car just got fluid changes, and that he used the ZF lifeguard fluid.
With the way bfsgross beats on that STR I wouldn't be suprised if he broke it sooner or later though
George
  #86
JagV8's Avatar
Er... I still can't manage that!!
bfs please explain a bit
ohhhh, wait, does "(used ZF)" mean "(used ZF's fluid)"?
  #87
Old 11-10-2010, 09:29 AM
bfsgross's Avatar
LOL! Sorry dudes. Yep, just swapped in new fluids. Sorry. George, she rips up the pavement better too...not a joke.
  #88
Old 11-10-2010, 10:35 AM
JagV8's Avatar
What was the old ZF oil like?
Did you change the filter?
The ZF sleeve?
  #89
Old 11-15-2010, 11:32 PM
DB6's Avatar
DB6
DB6 is offline
ud
I have an 04 XJ8 (30,000 miles) .
I noticed a small puddle of clear fluid on the garage floor today, had the car put on a lift and noticed some of the same around the rear of the tranny pan, wiped it clean and dry, did 100 miles, re-checked and it had stayed dry.
I read on here( and from other make forums that use this same trans) that the sealing sleeve can cause intermittent leaks, is this my most likely culprit?
I cannot see the source of leak.
Is it possible to replace the sleeve without removing the pan?
If the pan is removed for any reason should it be replaced with a new one ( I see the filter is built in??) and new gasket.
Is a special tool needed for the filler plug removal and should that plug be replaced, or is there a seal ring on it?
How is the new fluid put in, is there a filler tube available?
How is the fluid level checked and topped off in the future?
Thank you
David
  #90
Old 11-15-2010, 11:35 PM
DB6's Avatar
DB6
DB6 is offline
ud
Oh I forgot to ask,
is the original tranny fluid without color, is this the Lifgueard Fluid 6 plus stuff?
Thanks again
  #91
Old 11-16-2010, 02:10 AM
JagV8's Avatar
If it was clear could it have been water?
Obvious sources would be condensation (such as cool weather overnight), rain, a/c.
If it happened to me I'd rub it between finger & thumb (oil is quite distinctive) and - wait for it - taste a small amount. You will know if it's oil, and no it won't kill you
No jokes about spit or swallow, please!
DB6 (11-19-2010)
  #92
Old 11-16-2010, 06:55 AM
joycesjag's Avatar
Most likely from the A/C system, original ZF fluid is golden in color.
Yes, and it is visable when getting underneath the vehicle and looking where the electrical connects.
NO!
Somewhat cheap insurance, your call.
Read the beginning of this thread or read this one: https://www.jaguarforums.com/forum/s...joycesjag+saga
Again read above.
All covered above.
Thank you
Your welcome
David
Ahh come on John!
DB6 (11-19-2010)
  #93
Old 11-16-2010, 02:12 PM
DB6's Avatar
DB6
DB6 is offline
ud
Thanks for the responses.
It was def tranny fluid(about half a saucers worth after sitting in same spot for a week), it was visible just in the rear corner passenger side of the pan for about 3 inches around the pan bolt area;once dried and driven for 3 hours it stayed dry, that seems odd, can a leak be that intermittent?
Finally, it seems odd to me that this transmission has no way to check levels without going through this pian in the *** procedure, how much would a dip stick and tube have cost?
I know in the handbooks that Jaguar says "no check/top up required" which is fine till it leaks and then the owner has no idea what the fluid level really is.Evidently, from what I can see, there are no warning / check lights for low trans fluid, just a limp home mode for when it breaks.Seems risky with such an expensive item.
PS,
Should the filler and drain plugs be changed out too, or do they have seperate seal rings on them?
  #94
Old 11-16-2010, 02:41 PM
JagV8's Avatar
I think they have O rings (which of course will need renewing).
DB6 (11-19-2010)
  #95
Old 11-16-2010, 02:48 PM
joycesjag's Avatar
Yes, mine and member ccc did! Its the rubber sleeve that needs replaced.
Join the group!
Apparently to much, especially for a $65,000 vehicle.
Yes thats a bunch of whooie!
PS,
All replaceable gaskets come with pan not including the rubber sleeve.
Any other questions?
  #96
Old 11-16-2010, 03:32 PM
DB6's Avatar
DB6
DB6 is offline
ud
Thanks, and sorry again for any duplications.
I did ask about the warming of the fluids, lol, that sounds odd and alost erotic.
Seriuosly is it that critical?
  #97
Old 11-16-2010, 05:59 PM
JagV8's Avatar
Yep. Temperature matters (but there's a range that's OK).
DB6 (11-19-2010)
  #98
Old 11-17-2010, 03:41 AM
ccc's Avatar
ccc
ccc is offline
YES! My leak was intermittent and would drop about 100 ml every now and then. Say once every 400 miles. The problem is you don't know how much fluid is left.
DB6 (11-19-2010)
  #99
Old 11-17-2010, 05:24 AM
victor's Avatar
I get a small patch of wet under the car (S Type) it;s condensate off the air con. system and it's nothing to worry about, It takes a hell of a time to dry up. My previous X type with a manual box did the same. It is mentioned in the car handbook.
IF it's tran. fluid, that is cause for concern, a small puddle of clear water is not.
DB6 (11-19-2010)
  #100
Old 11-21-2010, 02:54 PM
bogart's Avatar
Originally Posted by ccc
Some additional pictures comparing the old and new sleeve (the old red one came out without any friction, the new one had to be pressed hard to replace. Another photo showing the difference between the old jaguar pan and the new zf part. One showing what the transmission looks like with the sleeve removed. Last two just shows where to jack up the car. The second pair in the photo is just a backup and doesn't touch the car.
In the pics of the pans does the fluid flow up the upstanding pipe or down it?
I'd like to know so I can backflush mine as I took it off today. One thing I came across was if you use a heat gun on the end of the pan bolts the 27mm torx ended bolts come away fairly easily. They need force but you hear a crack and then they are free. I am not sure if the replacement bolts have loctite on them but the ones I removed today certainly did. I am going to replace all of mine with 6mm hex bolts plus a thick washer.
Quick Reply: ZF transmission oil and sleeve change writeup with pics FAQ
