ZF transmission oil and sleeve change writeup with pics FAQ
#101
My unprofessional thoughts would be the ATF goes up the pipe and circulates through rather than down, since the pipe is attached to the filter portion of the filter and not the transmission pan. Again this is my shade tree mechcanic thought.
#103
Sorry if I'm reviving an old thread but my wife's 04 S-type has the leak.
I was about to order the seal when I luckily re-read the entire thread to find that it is necessary to drop the pan to change this damn sleeve!
No one explained why the pan has to be dropped - I'm supposing based on one of the photos that there is a latch (white plastic widget) which needs to be lowered for the sleeve to be removed - and that it is the pan which keeps this latch in the up position - is this correct?
With the extra years hindsight can anyone confirm which cheap tranny oils work well? The castrol multi-import for example?
Since not all of the existing trans fluid can be removed is there any issue with the inevitable mixing of the synthetic $40/qt ZF oil and the cheaper stuff?
Finally, I found the BMW warranty Tech sheet on replacing the sleeve in the 6HP trans. Thought I'd add it to the thread.
attachment.php?attachmentid=230005&d=1273726276 - Preview ebook on iSeepdF.net
It's a pdf download.
cheers,
ken
cheers,
ken
#104
#106
#107
#108
Did not change the sleeve as it was not leaking. Yet. But I did change the transmission oil Three times after raising it on jacks . About three quarts each time it was changed. Checked the temperature via infrared tool and kept it at close to the 45 degrees.
Red Line is what I used and it worked perfectly mixed with whatever was in there. I've pushed it numerous times and that trasmission thank God is performing perfectly with Red Line.
#109
I know it's always good practice to replace the pan gasket, but is it necessary? Thought I read somewhere that the pan gaskets reuse quite well but wouldn't want to waste time and effort in having to do the job twice.
Car has 60,000 miles on it.
Just so I havean alternative to the LR fluid, which Redline fluid is equivalent? Is there an API spec for the LR/Shell oil to use as a baseline?
#110
Received 6,324 Likes
#112
I was wondering why people were changing the pan.
The pan and the filter are inseperable?
How ....er...."funny".![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
This is like having to buy a new fuel tank every time you need to fill up with gas.
So, I need a new pan, 7 litres of liquid gold, and the $12 part that I only actually have a problem with.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
#114
#115
#116
http://s777.photobucket.com/albums/y...t=DSCF9109.jpg
#118
I did go ahead and ordered it online, scheduled to arrive tomorrow. After almost 2 weeks still never had any sort of response from CTSC. If they weren't the cheapest I wouldn't even bother with them.
As far as replacing the fluid and seeing people mention measuring the temperature and such, why can't I just measure the amount of drained fluid and replace that much back in?
Hopefully this fixes the shifting issues I've been having. Once the car warms up, driving in town (stop 'n go) is almost impossible as it constantly jerks out of first gear, if it makes it out of 1st at all before throwing a gear fault.
#119
The problem is that you don't know what the existing level is so you need to verify after filling.
#120
Exactly. If your level was high or low at the start using your method it will still be high or low when you finish. A temperature measuring multimeter doesn't cost much mine cost £7 approx $10-11 hardly a great outlay to assure the correct level.
