Dash Gauges
Old 04-21-2016, 04:25 AM
adenshillito's Avatar
Default Dash Gauges
Most operate at start up but usually with a few minutes all dead. Sound like heat getting to them at some point after engine warms up? Or what else might cause.?
Old 04-21-2016, 04:55 AM
yarpos's Avatar
Received 2,098 Likes on 1,264 Posts
Dont know if its the same in an S2, but in an S3 the dash gauges share a common fuse (no4 in main panel). Mine started developing the wanders and have improved after a clean. Might be worth giving then a clean up.
adenshillito (04-21-2016)
Old 04-21-2016, 05:29 AM
Received 10,483 Likes on 6,922 Posts
Memory, hahaha.
Up above the Tacho??? is an instrument stabiliser, and they are Lucas, and do fail.
Easiest way is to remove the dash top and reach in.
Option 2, push the tacho IN and rotate counterclockwise?, and pull out, then reach in and see what gives.
Its been a while, but all my S2's had issues like that and it ws that stabiliser and/or wiring connections, and good old bad earths.
The following 2 users liked this post by Grant Francis:
adenshillito (04-21-2016), littlelic69 (04-21-2016)
Old 04-21-2016, 09:50 AM
frostee's Avatar
I had a similar issue to this, where my battery gauge would start then just completely stop. My issue was the connection on the back wasn't on properly, looked like it may have been tampered with.
But anyways, best of luck and let us know your findings!
Old 04-22-2016, 03:39 PM
Hardly science as I couldn't fix out exactly what was what in that tiny space, but a clean out behind the dash with the gauges out seems to have fixed all the gauges at once. Not sure what I did however.
Old 04-22-2016, 03:51 PM
looking through front window behind the dash board with dash surface off.
jahummer
06-16-2016 02:35 PM
Greg in France
05-17-2016 12:12 AM
orangeblossom
04-27-2016 01:39 AM
Noah
04-23-2016 12:11 AM
SJWwalt
XF (X260)
04-21-2016 07:22 PM
Quick Reply: Dash Gauges
