Swapping out paddle shifters
Old 06-11-2015 | 12:16 AM
f_in_seattle's Avatar
Default Swapping out paddle shifters
Hey guys, I'd like to swap out my paddle shifters with something better than the black ones my car came with. I don't want to pay $600 for the aluminum shifters that Jaguar sells as an accessory.
Does anyone know if these ones from ebay will work?
New Blade Aluminum Steering Wheel Shift Paddle Shifter Extension for Jaguar | eBay
If not, does anyone know if anyone makes cheaper aftermarket versions of these shifters?
Old 06-11-2015 | 01:02 AM
Archeraph's Avatar
Worth a shot for $60
Old 06-11-2015 | 05:40 AM
Tel's Avatar
Tel
I will happily send you the set I have FREE!- They are absolute sh!te. Had them fitted to my old V8S. The grub screws rely on 'biting in' to the existing paddles to secure. The feel and look is just totally out of place.
If you search Google, there is a chap on your side of the pond I believe, making pukka CF paddles for XF's (all JLR and LR paddles are identical) which are really sweet.
You might want to try:
https://streamlinecarbon.com/v2/prod...tensions-pair/
Old 06-11-2015 | 08:24 AM
Stohlen's Avatar
If you do swap them out, I'll buy the stock ones from you... I've been thinking of working with some friends to make a full replacement unit that's larger and taller, but I need a stock set to use for dimensions and such.
Old 06-11-2015 | 09:32 AM
TXJagR's Avatar
The ones in the link provided only install over the factory ones if I am correct. There are a few options around and some members have ones similar to the ones you linked and only used double sided tape to install them as to not chew up the factory paddles with the grub screws. Do a search, there's some info floating around.
Old 06-11-2015 | 10:54 AM
Yikes that does look pretty bad. Ideally I don't want to glue anything over the existing paddles. I'd rather get a set of aluminum paddles that look just like the Jag OEM part but much cheaper. $600 is kinda ridiculous for that part. I'm surprised someone hasn't already machined an aftermarket replica but I guess they aren't that many cars to make it worth it.
Old 06-11-2015 | 01:20 PM
Schwabe's Avatar
You can get the aluminum ones for around $400 if you do some seaching. Also the paddles from the Evoque are identical and also come in red aluminum.
Evoque - Red Anodised Aluminium Paddle Shifter - [VPLVS0187CAY] - $499.99 : Range Rover Evoque Accessorie from Pure Evoque, Parts and Accessories for your Land Rover Range Rover Evoque
The following 2 users liked this post by Schwabe:
j.w.s (08-05-2015), Smoke Em (04-28-2016)
Old 06-11-2015 | 09:07 PM
nice, the evoque paddles look good but are just are expensive
Red Gearshift Paddle Set Genuine Land Rover Part Range Rover 2013 On | eBay
Old 04-28-2016 | 09:44 PM
cptslow's Avatar
Bump. Has anyone found any good alternatives?
Old 04-28-2016 | 09:54 PM
Smoke Em's Avatar
+1. Also has anyone installed the red evoque one on their F-Type? I think they look cool and the red is sharp especially with my red car, and black/red interior. If anyone has installed and has any pictures I would appreciate it..Thank you
Old 04-28-2016 | 10:56 PM
Stohlen's Avatar
I'm making an alternative. Unsure what the price will be yet if I can cheaply mass produce them. The design is done, we're just working on fitment at the moment and reliable actuation of the shifts. Its a long process.
Smoke Em (04-30-2016)
Old 04-28-2016 | 11:18 PM
Every time I see this thread I think stohlen has finally created his paddles!
Old 04-29-2016 | 01:06 AM
Fenton's Avatar
Default Alternative paddles
IRR, red paddles
Old 04-29-2016 | 07:39 AM
cptslow's Avatar
Originally Posted by Fenton
IRR, red paddles
Did you DIY the install? If you did, how difficult was it?
Old 04-29-2016 | 07:40 AM
cptslow's Avatar
Hurry up! LOL. The plastic stock paddles are a disgrace.
Old 04-29-2016 | 08:21 AM
ckosiek's Avatar
Fenton,
Your steering wheel is on the wrong side!!!
Anyway, the red does look good.....
Old 04-29-2016 | 08:57 AM
Fenton's Avatar
15 minute job, undo screw. paddle comes away from steering wheel, unclip lead, unclip old plug, clip in new paddle plug, reclip in lead, do up screw. Repeat other side. :-) The only slightly challenging part is aligning the screws when putting back but do one at a time rotating the steering wheel to the easiest position. Visual guide here http://www.mediafire.com/view/yoslvmt1oqn6eje/JAF_0119_1E_-_Aluminium_Paddle_Shifters.pdf or see sticky in this forum
The following 2 users liked this post by Fenton:
enderle (05-09-2016), Smoke Em (04-30-2016)
Old 04-29-2016 | 09:01 AM
cptslow's Avatar
15 minute job, undo screw. paddle comes away from steering wheel, unclip lead, unclip old plug, clip in new paddle plug, reclip in lead, do up screw. Repeat other side. :-) The only slightly challenging part is aligning the screws when putting back but do one at a time rotating the steering wheel to the easiest position. Visual guide here http://www.mediafire.com/view/yoslvm...e_Shifters.pdf or see sticky in this forum
Fantastic, thanks! Didn't want to pay Elevently billion dollars of labor for it if I found a set.
I'll check out that link. I haven't been very active on this forum until recently.
Old 04-29-2016 | 09:14 AM
Stohlen's Avatar
I mean... A copy does exist, it's just made of plastic haha
Old 04-29-2016 | 09:23 AM
cptslow's Avatar
HA! Well that's hardly helpful. Seriously though, I like the shape. Are your plans to make metal ones to sell? Do you have a projected price target?
Quick Reply: Swapping out paddle shifters
