Mark this thread as Unsold
WTB[Central US]: WTB: ABS Accumulator Motor and Pump for XJS
Old 06-11-2016, 12:36 AM
Safari's Avatar
Default WTB: ABS Accumulator Motor and Pump for XJS
I'm looking to purchase an ABS Accumulator Motor and Pump assembly for my 1990 XJS. Please contact me of you have one to offer.
Thank you!
Mark
Old 06-11-2016, 10:46 AM
XJsc-guy's Avatar
Default ABS Pump and Motor
Question- are you planning to transfer your original pressure switch to the new unit or do you need a replacement for that as well??
Or are you looking for the whole assembly- pump, motor, switch, and accumulator ball as as unit?
Old 06-11-2016, 11:21 AM
Safari's Avatar
All I really need is the pump. I have a good motor, switch and ball.
But I am flexible. Let me know what you have.
Thanks!
Mark
Old 06-11-2016, 04:44 PM
XJsc-guy's Avatar
Default Pump only???
If all you need is the pump, I'm pretty sure the units on the 93-94 XJ6 cars will work as well (they are different than the 90-92 XJ6- the pump is separate from the actuator). I thought I had one of these here but when I checked, no go- sorry....
Good luck
Old 06-18-2016, 08:51 AM
Safari's Avatar
BUMP!!
I'm still looking for a pump. It seems that most of the ones on eBay are from the XJ6. The position of the Accumulator ball and the high pressure line are opposite than the ones used on the XJS. The assemblies use the same electric motor and pressure switch but the pump castings are not the same. They are not interchangeable.
Please contact me if you have an XJS pump to offer.
Thank you!
Mark
Old 08-25-2016, 01:05 PM
Safari's Avatar
BUMP!!
aholbro1
10-14-2019 11:11 PM
sdkennedy1
07-10-2016 07:24 PM
bgiloni
XJ40 ( XJ81 )
06-12-2016 09:13 AM
Angel Hernandez Perez
06-09-2016 11:39 AM
fingers
05-21-2016 02:39 PM
Quick Reply: WTB[Central US]: WTB: ABS Accumulator Motor and Pump for XJS
