Dammmmmm again
Old 08-24-2016, 02:46 AM
malc4d's Avatar
Default Dammmmmm again
So I unplugged the two coil packs to clean up and lubricate the contacts and bugger me if one of the little tags that hold the plug onto the coil didn't just go 'ping..' and fly off. Now as this is the cable end is this this plug still available or does anyone have a scrappie car that they could cut a good plug off.
1991-2 V12
Old 08-24-2016, 02:58 AM
Daim's Avatar
These are genereic AMP superseal plugs. You'll get them in a well sorted parts shop or on ebay/amazon/...
Old 08-24-2016, 10:45 AM
Jonathan-W's Avatar
connectors and coil
connector plugged into coil
1991-2 V12
I have extra...
PM and I will drop one in an envelope to you...
do yourself a BIG favor.... BUY two coils NOW!
Ignition Coil URO Parts DAC4608 fits 89-92 Jaguar XJS 5.3L-V12
one went out and I have a restricted exhaust on bank b now I have to replace cats on...
(with the new coil it has 33% more power and gas mileage even with the melted bank B cat.)
so I ordered two more coils and have them in hand!
runs so smooth now...
The following 2 users liked this post by Jonathan-W:
Greg in France (08-25-2016), Sarc (08-27-2016)
Old 08-27-2016, 02:34 AM
malc4d's Avatar
Thanks Jonathan. Good idea as l am in the UK at the moment.
Old 09-10-2016, 09:10 AM
malc4d's Avatar
Jonathan. Just sent you a new PM
Old 09-17-2016, 07:24 AM
malc4d's Avatar
Arrived this morning Thanks Jonathan.
Old 09-18-2016, 11:18 AM
Jonathan-W's Avatar
Glad you received it...
I had bought a bunch for my injector project...
( new harness that I could plug in normally... or into a new computer system that could handle more zones or per injector)
the system we use does 4 zones (3 injectors per zone) the newer xj12 does 6 zones (with 2 injectors per zone) and waste spark...
we do odds evens per side... and use one O2 sensor..
would have been nice if the cast manifolds were odd even and used 2 O2 sensors.. but left over part from previous years and packaging (limited space) rule
Old 11-06-2019, 10:03 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Any parts numbers for these plugs?
Old 11-07-2019, 07:22 AM
scottpeterd's Avatar
These are what I used
The following 4 users liked this post by scottpeterd:
Doug (11-07-2019), Greg in France (11-07-2019), JayJagJay (11-07-2019), RickE (11-07-2019)
Old 11-07-2019, 08:51 AM
JayJagJay's Avatar
BeaUTifulll...
Looks like I'll be using them too!
Thank you so much!
Old 11-07-2019, 09:00 AM
Ive been using them on my TVR rewiring project.
As Im making up my Jag injector harness, I found the matching connector also on Amazon.
Old 11-07-2019, 09:26 AM
JayJagJay's Avatar
Nice! I feel lucky... For some reason the harness on my XJS was in decent condition... What I do need to replace are the FI connections tho. And I will.
Thanks for this. I can use the coil products,,, and I was reading a thread by someone else here that can as well. Good digs! Be Good!
Old 11-07-2019, 06:52 PM
stran0020's Avatar
for the stock connectors it only uses 3 wires correct? or is my ignition coil connectors missing a wire
Old 11-08-2019, 05:26 AM
JayJagJay's Avatar
Good question... I'll have to go check...
04-24-2019 04:57 AM
TheWarlock
05-30-2016 02:55 PM
Kief
04-26-2016 10:29 AM
JimC64
Detailing / Car care
11-24-2008 05:01 PM
Quick Reply: Dammmmmm again
