Is there any alternative to these Fuel Injection Clips?
Old 09-06-2016, 06:25 PM
orangeblossom's Avatar
Received 3,814 Likes on 2,641 Posts
Default Is there any alternative to these Fuel Injection Clips?
Hi Guys
The worst part (for me) of removing the Fuel Injection Rail was taking the Wire Clips off the Injectors to remove their electric plugs.
Even with a very small sharp screwdriver, those wire clips are a total PIA to take off.
Is there a more updated type of Clip available and if so where can I get some?
Old 09-06-2016, 07:02 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Originally Posted by orangeblossom
Hi Guys
I have found a gentle see/saw action on the plug while applying pulling force (also gentle) they unplug no worries with clips in place.
orangeblossom (09-07-2016)
Old 09-06-2016, 07:29 PM
BC XJS's Avatar
I just wiggle them off as well
Old 09-06-2016, 11:52 PM
Jagboi64's Avatar
Received 3,190 Likes on 2,104 Posts
I use a pick and lever one side off, then the other usually come off fairly easily.
Old 09-07-2016, 02:50 AM
Daim's Avatar
You can use standard Bosch FI plugs BUT they will not sit right. Problem is the cut out around the injector.
You could instead make a little extension and use the ore modern plugs like AMP Superseals between the vehicle loom and the injector. Kind of like 12 adapters. Should male removing them easier. With age, they tend to crack...
Old 09-07-2016, 02:55 AM
rgp's Avatar
rgp
rgp is offline
They just pull off while wiggling them. be a bit rough with them
Attached Thumbnails Is there any alternative to these Fuel Injection Clips?-100_1671.jpg
Old 09-07-2016, 03:32 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
my way of fixing the Bosch injector mounting , custom aluminum rail, o-ring top and bottom, i undo end fuel lines , two bolts hold rail and just lift upwards, and rail is of, injectors stay in place .
i did away with that top hose setup, fire potential(rare).
and my injector plugs have no clip , never had one loose in 21 years! might be over kill engineering
Attached Thumbnails Is there any alternative to these Fuel Injection Clips?-dscn8787.jpg
Old 09-07-2016, 04:26 PM
Hi Ron
That's an ingenious piece of Engineering
ronbros (09-09-2016)
Tomica
Other Areas
09-20-2017 01:50 AM
BobRoy
49
09-18-2016 10:48 AM
hisport
04-03-2016 07:34 PM
tigger
04-02-2016 08:56 PM
Exterior
03-30-2006 03:41 PM
Quick Reply: Is there any alternative to these Fuel Injection Clips?
