Is this Brake Fluid all the Same?
Hi Guys
They are Both DOT4 but the Round Tin says 'Synthetic' while the other one does not, from what I can see. (Although it might be?)
I may not have enough in the square can and unless there is a difference may have to mix them.
The Round Tin is about half full and the square one about 1/4 full.
Going on past experience I will probably need to use all of it to thoroughly bleed the Brakes.
They are both DOT4 but the Tin on the right says Synthetic, though the other one might be as well.
Received 2,266 Likes
The following 3 users liked this post by Mikey:
orangeblossom (09-27-2016)
TJChid
10-17-2016 05:45 AM
