Air flow switch stuck on.
Received 3,975 Likes
I am having a problem with the airflow switch in my ser 2. When I switch it off it stays on low and won't go off.....if I physically hold the switch in the off position it will switch off for a second or two and then come back on. It would appear the switch is broken or there is dirt or something interfering with it.
My question is do I need to remove everything to get to it or is there an easier fix?
Jim,
Radio out, knobs off, 2 switch nuts off, CAREFULLY remove that facia, watching the fibre optic strands, and then you will see 2 SMALL hex heads, at 12 and 6 o'clock.
Reach in the radio opening, slim fingers helps, and feel the nuts at the back, and tighten the small bolts firm.
I have found they loosen with age, opposite to us, and a simple tighten restores normal function.
I have never removed that switch, but it looks like fun, not.
Grant Francis (01-25-2017)
The following 2 users liked this post by Daf11e:
Grant Francis (01-28-2017),
littlelic69 (01-29-2017)
