5hp24, which aftermarket A clutch drum should I buy
I will need to replace the A clutch drum in the 5HP24, ZF revised part number 1058-270-040. The ZF part is both expensive and backordered.
Who makes a high quality aftermarket A clutch drum for these transmissions? There are a few options I found online:
One from DACCO:
one from cascade:
ZF 5HP24 Heavy Duty Input A Clutch Drum
The version from cascadetransmissionparts seems to be lacking the groove for the snap ring? I am curious as to how the contents of the drum will be retained in place without said snap ring?
And one from powertorque:
ZF 5HP24 5HP24A 01L TRANSMISSION "A" CLUTCH DRUM NEW REINFORCED UPDATED DESIGN FITS '96+ REPLACES 1058-270-040 - The American Powertrain Warehouse
Please let me know if you have experience with any of the above, be it positive or negative.
Also, please let me know if you have installed transgo 5HP-24-PR1 presssure regulator upgrade, what was your experience?
One from DACCO:
one from cascade:
Read this post where it was recently discussed
https://www.jaguarforums.com/forum/x...d-drum-174373/
Also this thread.
https://www.jaguarforums.com/forum/x...anyone-176625/
And one more.
https://www.jaguarforums.com/forum/x...-issue-176509/
There are others but these will give you some info.
Also this thread.
And one more.
juha_teuvonnen (02-14-2017)
Also this thread.
And one more.
Also this thread.
And one more.
juha_teuvonnen (03-18-2017)
