What did you do to your X300 today?
Old 03-03-2017, 06:36 PM
RFXJ12's Avatar
Originally Posted by SFPat
Recently replaced valve cover/plug seal gaskets (had oil in 1st plug), plugs and coils. Runs smooth now but still have to address an issue with fuel system (pump going out or clogged filter? Occasionally "stalls" as if no fuel, then recovers)
New fuel filter and champion plugs always a good idea. When my 96 VDP was doing what you are describing, 6 new coils cured it.
  #262
Old 03-09-2017, 08:25 PM
michaelmedina2005's Avatar
installed 4 inch air intake to oem airbox,cleaned engine bay
i removed the label and covered tube with fiberglass wrap,sealed with silicone spray
exhaust manifold heat sheild with exhaust wrap,both inside and out,right now i have a temp of 350 with ceramic coated manifolds,cuirious to see what the differance will be
  #263
Old 03-10-2017, 10:01 AM
dagny747's Avatar
Rear wheel bearings and partial fix of the emergency brake, so that it does not stick and rub, but it also doesn't work
  #264
Old 03-10-2017, 11:46 AM
Tcasmarcus's Avatar
Installed a new gear knob I purchased on ebay. My first impression was it looked kind of too shiny and a bit tacky. Maybe I'll remove it again 🤔
The original is black leather with a silver stripe
  #265
Old 03-10-2017, 02:20 PM
installed the oem heat sheild
with a layer of thermo-tec exhaust tape ,inside and outside,the temperature dropped another 100 degrees,for a total of 245 degrees measured with my lazer temp tool
  #266
Old 03-10-2017, 06:47 PM
nsxguy7's Avatar
I removed 20 year old window tint, replaced my headliner, and a handful of missing or broken interior fasteners. Also pulled about a dozen door dings that were so severe that they looked like vandalism. Primed and currently block sanding for paint.
  #267
Old 03-13-2017, 05:42 PM
repaired and reinstalled heater pump
heater pump now woks again for a total of 8 dollars for the brushes
cleaned and vacumed
freshly opened,ton of brush dust,no brushes,just springs
new brushes installed
file used to rub oversized brushes onto, until small enough to fit into golden brush containers
  #268
Old 03-14-2017, 06:26 PM
reinstalled heater control valve unit,all is well again
  #269
Old 03-19-2017, 11:50 AM
Rivguy's Avatar
I had been having trouble with squealing drive belts. So I replaced both belts and the idler pulley. I thought that I had tightened them up enough but still had squeal on starting up. Searching the forums I read the discussion about deteriorating crank pulleys so I wondered if that was the problem. I was planning on marking the pulley as described in the posts. Of course I've been dragging my feet for months. I was looking through a new copy of Jaguar World magazine and they ran ran article on servicing the XJS V12 motor. What interested me was the description of how to check belt tension with the old V belts and the newer flat drive belt. They rec commended that you twist the belt in the middle of the run with your fingers. It should only twist one quarter of a turn.I checked my belts and both belts could almost be twisted all the way around! Pushing the belts up and down I thought that they had been installed tight enough but I was quite wrong. Using the "twist" method gave great results. No more squeal! No need fro a special tool. Quite satisfied. Now on to the bushings!
The following 3 users liked this post by Rivguy:
al_roethlisberger (03-19-2017), littlelic69 (03-21-2017), Scotlad (03-19-2017)
  #270
Old 03-19-2017, 12:29 PM
al_roethlisberger's Avatar
Default Good tip!
That's a good "shade tree mechanic" tip for the v belts. Good to know!
I've got to replace my SC belt soon as it squeals under high RPM.
I've also used a "krikit" click tension checker to tension the belts. It is cheap and easy.
  #271
Old 03-22-2017, 04:00 PM
crvols's Avatar
I replaced my J Gate micro switch with a new one I ordered from England. The hardest part was drilling out the old studs it was anchored with. Not like anyone would ever want to change a $5 micro switch in the future so, they attached it so it can't be removed! :-0( Once out I put the new, much smaller switch in with mini-screws and nuts and it works as new.
littlelic69 (03-23-2017)
  #272
Old 03-26-2017, 06:53 PM
Replaced the fuel filter. It wasn't nearly as difficult as had been made out for a change. Usually the "difficult" jobs seem to turn out to be even worse than suggested
I replaced an AC Delco filter with a genuine Jaguar part and replaced the two o-rings.
It was MUCH easier to blow through the Jaguar filter than the AC Delco unit, so perhaps it will flow better, although that may not be a fair test since the AC Delco filter was still damp and the new Jaguar filter was dry. The old AC Delco filter had been on the car for at least 40+ thousand miles and almost 3 years, as that's how long I've owned it.
Also noticed that differential drain plug seemed to be weeping, and I was able to turn it a few degrees tighter without much effort. So maybe that will stop the weep.
I have a set of used XJR injectors with Jaguar Fuel Injector Service and hopefully will get them back before next weekend.
  #273
Old 03-29-2017, 07:12 PM
cleaned engine bay,installed split loom,3m carbon fiber onto wiper mother
3m carbon fiber on wiper motor
  #274
Old 03-29-2017, 09:59 PM
Thumbs up
Mr. Faircloth from the injector cleaning service called today to provide a report on the results of the cleaning, which is great customer service. He was able to turn them around in just a couple days.
I haven't received them yet, but suspect they'll arrive in a few days.
The results are as follows:
Below are flow test results on your injectors. This is after 30 minutes of ultrasonic cleaning. Test date Wednesday, March 29, 2017. Tested at 3 Bar pressure. Test time 10:15 am. Flows shown are for 60 seconds, full open (100% duty cycle).
1) 400 cc
2) 408
3) 404
4) 408
5) 408
6) 400
Average flow 404.7 cc
High Flow 408
Low flow 400
Spread 8
Deviation 3.59 %
Summary...The deviation is very slightly high. 3% is typically the max. However, I don't think it warrants buying and/or sending further injectors to test and match.
I have replaced the upper and lower o-rings and the filters.
Will box and return ship on Thursday.
Print this for your records.
SD Faircloth
Also received my new Bosch fuel pressure regulator today and other misc parts from Terry's Jaguar to remove the intake, etc. in preparation for cleaning the throttle body and intake tract. Terry's was also great to work with and provided very personal service when trying to fill the order and deal with items that were no longer available.
  #275
Old 03-30-2017, 07:40 AM
Scotlad's Avatar
It would have been interesting to see the flow results before the cleaning. I also have bought parts from Terry's and liked their prices and service
  #276
Old 03-30-2017, 07:14 PM
put carbon fiber wrap on engine bay fuse box covers,and also on cam cover cap
  #277
Old 03-30-2017, 08:36 PM
Yeah, I told him that I had pulled them from a wreck, so he didn't think that getting "before" flow results was that helpful since the goal was cleaning them and making sure they met spec. Not a problem, but it would have been interesting. Plus I was in a hurry, but normally he would have.
Scotlad (03-30-2017)
  #278
Old 03-31-2017, 05:25 PM
installed 3m di-noc carbon fiber wrap onto air pump,and abs...,engine bay is looking much improved,cant wat to paint the cam cover,extra wrinkle black with carbon fiber on the coil pack cover,and fuel rail cover.
  #279
Old 04-02-2017, 03:25 PM
installed wrapped rail cover and coil p[ack cover,nest stop,extra wrinkle black treatment for cam cover
  #280
Old 04-03-2017, 06:40 PM
almost finished,did the maf
Quick Reply: What did you do to your X300 today?
