LCD panel repairs all the same on heater unit, clock, radio and Trip Counter?
I have read many threads about LCD repair on the clock, but there seems nothing on others. Refurbished units especially the radio are sold at handsome prices, but can I assume that the LCD panels on them are all the same and can be fixed by replacing the LCD display ribbon cable? The LCD panel on the heater unit is still showing up fine, the clock's is fading out, and the radio's shows internal leak. I thought of removing all three units on the central console for a one-time fix. The trip counter still shows up but is a bit blurred, possibly on the way out, and I presume replacing the whole instrument cluster with a better one would be a better solution?
Found this very useful thread on backlighting for all display panels on our X300:
https://www.jaguarforums.com/forum/x...dimming-38712/
Backlighting apart, first and foremost is to tackle the LCD display in the AC unit, clock and radio. There are many write-ups and repair-service offers on the clock, can't find any on the rest.
I used these:
JAGUAR XJ series Cluster Speedometer T5 bulb Lot of 4 | eBay
the ones I took out did not have blue covers, were clear as are these. Replaced them both and my odometer seems as it should be. bright but not washed out.
As a rule, I have always heard of the clocks failing, but not the rest. The climate control LCDs seem to be better made.
Not sure what's up with your odometer display. At first I assumed it was just a reflection or glare in the photos, but it's not?
It's not hard to replace the entire instrument cluster you could always do that.
Many thanks. I shall try replacing the backlight of the odometer display first to see if the display would improve. I suspect, however, that the window plate might be burning out due to overheating from improper bulbs installed by the previous owner.
The climate display is holding up well so far, but might fail sooner or later. Was planning to fix 'em all at once, so I asked. The radio display seems the toughest one to deal with. There hasn't been been any mention of fixing it. I now see a leak in my radio display window, but have to find out if the radio functions properly once I recover the radio code. Obviously, if the radio is out of order it would make more sense to have it replaced with a modern head unit.
It's easy to pull the instrument cluster out. There are 4 screws from underneath, 2 on each side. They are roughly in line with black vinyl trim edge of the cluster. With your head in the footwell and looking up you'll see them. Lower the steering wheel and bring it forward as much as you can and the cluster should work loose. There is a tang at back that needs to get pulled free and then when loose reach on behind and disconnect the wiring harness.
The bulbs are actually fair distance from the display.
Qvhk (04-13-2017)
