valve cover bolt vacuum leak
Old 06-04-2017, 11:00 AM
jagstuart's Avatar
Default valve cover bolt vacuum leak
finally got around to smoking the engine and found this bolt leaking smoke. passenger side valve cover bolt. maybe i didn't search the right words but didn't see much in threads. what's next guys? temp fix with a proper size washer and an oring, no codes no mil/cel on shake downs. well heck! spoke too soon again. guess i'll hook up the smoker and burn another cigar.
valve cover bolt passenger side below PCV
