Mod lights
Old 03-31-2017, 10:25 PM
Dell Gailey's Avatar
Default Mod lights
Trunk (I can see now), footwells. Next is LED strip under hood (same reason, so I can see).
Attached Thumbnails Mod lights-20170331_203911.jpg   Mod lights-20170331_203945.jpg
Old 05-03-2017, 11:28 PM
Default New update
Engine bay = I can now see!!
Attached Thumbnails Mod lights-20170503_190239.jpg   Mod lights-20170503_212215.jpg
Old 05-04-2017, 06:29 AM
Gophat's Avatar
That is super cool. Where did you get the strip l.e.d from?
Old 05-04-2017, 11:49 AM
From here =
Then bought a door hinge pin, drilled a small hole just to the rear and slightly right (looking from front of car towards engine bay) of the driver's side adjustable hood height pad in front of the fuse box. Ran power through small drilled hole in fuse box, up under the slight protrusion of driver's fender to lights, return ground from lights to door hinge pin for hood close light cut off. Checked mounting height of pin with a little molded piece of "play dough" to assure mounting height.
Old 05-04-2017, 12:08 PM
Pics
Attached Thumbnails Mod lights-screenshot_2017-05-04-10-58-31-1.jpg   Mod lights-20170504_110141.jpg   Mod lights-20170504_110055.jpg
Old 06-21-2017, 10:45 PM
More lights =
Old 06-22-2017, 10:48 AM
wa3ra's Avatar
Guten Morgen! Let loose the lumens!
I like it!
Old 05-19-2018, 11:50 PM
Added DRL lights =
