Cant open trunk (boot)- battery disconnected inside
Old 07-29-2017, 12:15 PM
karlchap's Avatar
Default Cant open trunk (boot)- battery disconnected inside
OK, I'm an idiot. I was working on a door lock problem last night and not wanting to drain the battery while I left the door open overnight, so I disconnected the battery - then closed the trunk lid. The car is new to me so I didn't even think that there would be no key release at the trunk......
Can I apply power somewhere to restore momentary power to get the trunk open?
Any advice would be appreciated.
Old 07-29-2017, 01:33 PM
King Charles's Avatar
Received 1,020 Likes on 741 Posts
The key release is beside the rear XJ8 badge.
Old 07-29-2017, 01:42 PM
karlchap's Avatar
I have the XJR R edition, no key hole I'm afraid. I did resolve it by applying 12VDC in the engine compartment and used the fob to pop the trunk.
Thanks!
Don B (07-29-2017)
Old 07-29-2017, 08:40 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Yeah, that should normally work.
However, as there was no "R" version of the XJR, I presume someone put an aftermarket decal / sticker / badge over it, the hole for the key should be underneath.
Not a bad idea to restore it to the original, you never know the next time you will need it .
Oh yeah, check if it works, they used to gum up, can be worked loose with WD40, then use graphite after everything is dry.
Old 07-29-2017, 10:09 PM
karlchap's Avatar
After really LMAO I went out and looked and felt behind the liner and low and behold!
I really know VERY little about these cars :-)
Old 07-29-2017, 10:14 PM
ericjansen's Avatar
Ha, someone filled up the recess...now , you are lucky the hole is still there then ...
This is how it looked ex-factory for a XJR:
karlchap (07-29-2017)
Old 07-29-2017, 10:32 PM
karlchap's Avatar
Thanks Eric!
Old 07-30-2017, 05:38 PM
"And I now see" said the blind man lol, this forum is awesome.
Old 07-31-2017, 02:16 AM
Daim's Avatar
Ypu can also apply power in the engine bay to the main terminals and like that feed the boot unlock system
Old 07-31-2017, 05:20 PM
CharlzO's Avatar
Unless you had left the negative cable resting on the positive post to do a hard reset prior to the lid closing. Things get rather warm quickly if you try it then.
motorcarman (07-31-2017)
Old 08-05-2017, 08:05 AM
KidRock'n's Avatar
I got myself into a similar situation last summer when I locked my keys inside the trunk. Wound up having to drill a hole behind the license plate to pop the release. Consider yourself lucky!
Old 08-05-2017, 07:37 PM
Lady Penelope's Avatar
If you take a straight edge and make an X in the middle behind the licence plate you will be in the exact spot to drill a hole to be able to lever over the trunk release , been there , done that . Use the 4 plate mounting holes for the corners of the X . Same on X300 and X308 .
