Water pump+Hoses+Alternator+Rear coolant crossover
Old 09-03-2017, 03:25 PM
Bigg Will's Avatar
Making progress.
Old 09-12-2017, 09:17 AM
Bigg Will's Avatar
I AM ABANDONING THIS POST FOR THIS ONE!
https://www.jaguarforums.com/forum/x...9/#post1758337
Old 12-24-2018, 01:39 PM
TheV's Avatar
Default replacing this pump
Thanking you for this post as I have been struggling with this pump from everything including ordering wrong pump to installing it improperly at least 3 times. now have new O rings and going to line it up once more. I am acquiring this vehicle from my daughter and enjoy the car but the information on fixing things that go wrong is scarce.
Old 01-13-2019, 05:28 PM
maximus150's Avatar
Thumbs up
this post is right on time I have to replace my front crossover tube, it leaking at the very bottom in back of the water pump I thought it was the black short tube that connect the water pump and the oil cooler
Old 01-16-2019, 04:33 AM
Bigg Will's Avatar
This thread goes into a little more detail on that.
Old 01-16-2019, 09:01 AM
maximus150's Avatar
Thumbs up 2013 XJ coolant leak
Thanks Bigg Will
that post was very helpful, my tech- Manual don't really explain it much, I'm awaiting on parts right now but while I have the SC off gonna go your, change while its expose...
Old 01-18-2019, 04:57 PM
maximus150's Avatar
are those bolts inside the intake manifold the only ones that bolt it to the the head
Old 01-18-2019, 05:54 PM
davetibbs's Avatar
Yes. But if you've never removed the supercharger before, the interference fit pegs underneath it can make it tight. I had to use considerable force (bolting two straight metal bars to the whole supercharger/inlet manifold assembly and rocking it with a gym buddy) to get it off.
maximus150 (01-18-2019)
Old 09-21-2019, 08:37 PM
jaytee's Avatar
Thank you for the amazing post @Bigg Will , I'm going to be tackling this on my mom's Jag once I source all the needed parts. She has a coolant leak from a hose between the supercharger and firewall.
What oil did you use for the supercharger service? and what is the recommended/required quantity?
Thanks!
Old 09-21-2019, 09:39 PM
Bigg Will's Avatar
Thanks!
I abandoned that post for this one.=
SC supplies=
SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
jaytee (10-02-2019)
Old 04-16-2021, 08:41 PM
Carlos Saez's Avatar
I'm starting to get a minimum coolant loss, as a precaution it's worth changing everything and described here it's a 11 year old car it won't hurt.
Could you please list all the part numbers involved?
Thanks.
Old 04-17-2021, 08:37 PM
clubairth1's Avatar
Received 2,424 Likes on 1,906 Posts
Hi Carlos
Just to let you know Bigg Will sold his Jag and moved on some time ago.
But follow the links he posted I think he has part numbers as he was very though in his repair threads.
Too bad he no longer posts. He did a lot of good work.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
