What did you do to or buy for your XJ-S/XJS today?
Old 09-10-2017, 04:07 AM
rgp's Avatar
rgp
rgp is online now
new 215-65-16 front tyres as fed up with slight contact of spoiler when going over speed humps for which there is loads and loads and all different heights
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-100_2205.jpg
  #802
Old 09-10-2017, 10:33 AM
Daim's Avatar
Alternator is now in pieces. Case prepared for blasting. Checked my bracket from the 77 XJ-S would accept the bolt: no, the 120 A alternator had a larger screw (10 mm). So I drilled the hole a little larger.
PAS pump is separated again. Case will be resprayed, dent removed. New rubber rings. Then refit.
Also tested the belt order... I think when they are due again, I'll take the radiator out for the job!
  #803
Old 09-10-2017, 12:29 PM
Daim's Avatar
Oh, and I just ordered some new bearings, a regulator and a capacitor für the 120A alternator... So that should be working perfectly when ready...
  #804
Old 09-10-2017, 04:39 PM
JigJag's Avatar
Among some others, I finally set that right exhaust tail piece at the right angle.
Both clamps failed trying to remove them. And, at least around here, no one sells these style of clamps. Anyone know what they're called?
Its a solid steel band that is stretched out on one side to hold a internally threaded collar. A small hex ( torx? ) screw would go through this and pass through the hole made for it in the tailpiece to press against the tailpipe securely. The bradded on collar for the screw spun in its hole. That was fun to get off.
I put a 1" long 5/16 18 stainless bolt in it with a nut either side of the strap. Snugged it down tight and lock it in place with the outer nut. I would like to replace these clamps if anyone knows what they're called or where I can get them.
While I had them off, I cleaned both tailpieces. They were pretty nasty.
Even after they were "clean" they had some bad discoloration. Rust from somewhere above them.
But I guess these are stainless! They cleaned up real pretty.
When I drove her to the auto parts store for clamps without the tailpipes in place, I was really shocked at the difference in the exhaust note! These not only greatly reduce the exhaust note volume in the cabin, but without them it really resonates in the body spaces around the rear of the muffler. Very throaty. Probably a bad idea carbon monoxide-wise but sounded like I'd swapped the rear mufflers out.
Jonathan-W (09-11-2017)
  #805
Old 09-12-2017, 05:54 PM
944xjs's Avatar
Sometimes life just goes your way. Went to the junkyard to get an AAV... happy that it looks fresh and had an rtv seal so I'm hoping that's going to fix my funky idle... side note, the car had this Nardi in it. Didn't want to just leave it there.... 🙂
Just needs a bit of cleaning. Anyone know the model?
  #806
Old 09-12-2017, 10:32 PM
89 Jacobra's Avatar
Received 1,168 Likes on 677 Posts
As far as the model it looks very similar to my 89, judging by the dash, radio, and switches? But I'm pretty sure they looked a lot alike for several years. Just not sure how large a spread in years. I like the wheel, did you get it while you were there and if so would you like to sell it? It's a lot nicer then that big thick rubber one in mine.
89 Jacobra
  #807
Old 09-12-2017, 10:51 PM
Daim's Avatar
89 Jacobra
The XJ-S there is older as the skislope is all plastic and differently shaped. I'd say 86.
But U think he asked more so what model the steering wheel was
To topic:
I took my alternator body to be sandblasted. Can't refit a filthy dirty old 115A in my car...
  #808
Old 09-12-2017, 11:45 PM
944xjs's Avatar
89 Jacobra
Ha, yeah I meant model nardi. The car itself is a 76'. I'm putting the wheel in my 88'. I'm wondering if I should rip the heads off of it to sell or possibly up the power on mine someday...
  #809
Old 09-13-2017, 02:05 AM
rgp's Avatar
rgp
rgp is online now
I think to rip the heads off you will need to take up residency at the knackers yard. lol
  #810
Old 09-13-2017, 05:59 AM
Daim's Avatar
Yeah. It's no yank V8 with like 10 screws and done
  #811
Old 09-13-2017, 09:18 AM
944xjs's Avatar
haha
  #812
Old 09-13-2017, 09:44 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
The reason is that, without the tail pipes, the exhaust ends within the tunnel in the bodywork. This allows the tunnel to resonate, much like a trumpet, when the exhaust pulses exit the back straight through silencer. Anyone who wants to try this out for themselves, just remove the tailpipes and go for a spin.
  #813
Old 09-13-2017, 11:41 AM
Jonathan-W's Avatar
yank the heads off... well we are in America... so if we taffy pull the heads off by an American it would be "Yank"ing the heads off...
  #814
Old 09-13-2017, 11:45 AM
Daim's Avatar
Yank v8 = 'Murican V8
Tis maybe a US forum, but these vehicles here are manufactured by her Majesties approved motorised coach builders
  #815
Old 09-13-2017, 01:23 PM
944xjs's Avatar
Well with the ridiculous prices of everything it might be worth attempting in a day. Not sure what it's like in Europe but finding junker xjs's is not easy.
  #816
Old 09-13-2017, 01:28 PM
Daim's Avatar
Here in Germany it is impossible to find any XJ-S on the scrap yard. VW, Benz, BMW, Audi, Opel, Ford, ... Standard. A Jag is rare. XJ-S unheard of.
  #817
Old 09-13-2017, 04:50 PM
warrjon's Avatar
Yep we have the same problem junkyard XJS's are NON existent, need to go to a specialist Jag wrecker.
  #818
Old 09-14-2017, 09:24 AM
Jonathan-W's Avatar
I thought this was a world WIDE forum... and we have the benefits of great members form Germany, Canada, England, Australia, and yes even the few Yanks here and there...
  #819
Old 09-15-2017, 12:26 PM
Daim's Avatar
Alternator has been overhauled. And then I remembered, that I had another one in storage! The new bearings are a little stiff at the moment but like all bearings shouldn't be stuff for long.
  #820
Old 09-15-2017, 09:40 PM
Doug's Avatar
Received 10,873 Likes on 7,151 Posts
Heh, heh....every now and then I have to paw through all my boxes, bags, and tubs of parts just to remember what I have and where it is
DD
Jonathan-W (09-19-2017)
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
