Thanks lads
i'll try fuel filter
was also thinking misfire
i will try my code reader to see if any are stored
is it difficult to replace fuel filter and spark plugs ?
cheers
possibly the throttle body needs to be removed and cleaned
clean mass air flow sensor
keep driving hard until it gives u a check engine code
Just one thing when i bought the car it was low on petrol, light was on, i put £10 in and light is still on , theres no leaks, i'm wondering if its sucked up some dirt from tank, if it was gearbox ( auto) would i get an engine light come on if there was a fault with it?
Also how involved is it to change fuel filter and plugs
P-1108 =
P1108 EMS
OBD II
MAP Sensor sense circuit
high voltage
Ignition ON 10 seconds 2 N ECM Default:
– Default value of 1.013 BAR
(29.92 in hg) used
PI1
-127
MAP Sensor sensor ground circuit (to splice):
open circuit
MAP Sensor to ECM sense circuit:
short circuit to high voltage
MAP Sensor failure
I'll have a look at throttle body next week
now the Map sensor has been cleaned I don't get the code anymore but EML Led doesn't work
Would a dodgy Map cause above symptoms
just a few more things
the remote key fobs won't unlock
they lock / boot release and lights button work tried the ignition flap that's ok
it won't pair the fobs with car either
also drivers seat electrics don't work
are these common faults ? And easily fixed
Probably best to start new threads if you are having other unrelated issues to allow you to get quicker and better responses to those issues.
fuel filter is easy, 5 minutes
spark plugs are a pain as intake and other stuff has ro be removed to access them. takes about 2 hours the first time
