carb pin offset
You have SU HS8 carby's, that is the jet you are looking at. It is adjusted by the mixture screw.
There is a write up in the "how to quick links" at the top of the XJ forum.
If you go to the link below there is a downloadable PDF in post #14. There are some earlier in the thread but not complete.
https://www.jaguarforums.com/forum/x...17/#post928571
adenshillito (09-24-2017)
Read before, did a quick re read. I think when it speaks of the alloy bridge and the brass jet head being flush, here us where I am after clarity.
Neither of the right hand carbs I have here (aud 2510) comes flush with the bridge but both left hand ones do come flush. So is that a design offset or a remarkable coincidence in two sets of carbs.
Both of mine will adjust to flush with the bridge(or maybe a mm or so below it). Just a thought, maybe the mixture screws are not long enough or mixed up with the idle screws.
Idle screws are 4 BA x ¾” SS cheese head, Mixture screws are 4 BA x 1” SS cheese head. Lock nuts are
4 BA Brass nuts. You can try to source these locally but in Brisbane I found only two 4 BA bolts and they were the wrong length, 5/8” . SU Midel in Sydney had them at a premium price.
I sourced them online for 10 of each idle & mixture screws + 20 locknuts for less than I could get 2 scews the wrong length in Brisbane. Link below, and paid with Paypal.
BA Fasteners, Imperial Fasteners, Micro Metric Stainless, Small Screws, Ba Screws, Ba Bolts,
Grant Francis (09-24-2017)
While cleaning noticed much sticky black stuff in rings around some parts and figured later that this must be all that remains of rubber o rings that have melted.
The newer carbs have a rigid wire between the depression levers that allows both carbs to be engaged at once, and it has a cover that links both carbs with a lever but unclean how these once operated.
Curious bridge and lever joinjng both carbies
adenshillito (09-25-2017)
