Official XJ ( X350 & X358 ) Picture Thread
#184
I converted from CATS to BC Racing 32 way adjustable coilovers. It is lowered enough so there is no wheel gap. It had the "vehicle too low" message on the display until I disconnected the height sensors.
I drove it from Florida to Tennessee and back and it was a good ride. Did rub occasionally over heavy bumps at higher speeds. I got the fenders rolled and that took away any rubbing. Never rubbed since.
#186
Exexpat, does 30 mm lowering allround keep enough space under the wheel arches when you go through bumps or have to make sharp turns?
Also what does happen when speed goes over 100 mph (further 15 mm lowering), ... in case?
Jazzy, is your car slightly lowered with SDD or not?
#187
#189
#193
#194
#195
#198
#199
#200
chillyphilly (12-26-2017)
