Why the E-diff
Per Wiki: "The Ford Motor Company lost $250 million on the Edsel's development, manufacturing, and marketing. The very name "Edsel" became a popular symbol for a commercial failure." "The company lost $350 million, or the equivalent of $2,900,000,000 in 2016 dollars, on the venture."
or sealed for life transmissions.
Seriously though, here's the read on it:
https://en.wikipedia.org/wiki/Electronic_differential
Yesterday, just for grins, I tried to shove a stranded bicycle brake cable down my oil suck-out-tube to see if I could find a level for Full Oil. It only went down about a foot and wouldn't insert further. No oil at that point.
Oh well, it was worth a shot.
Now back to the why an E-Diff instead of a normal posi
One problem with a fixed-lockup differential is understeer. A welded diff is the extreme case. In theory, an electronically variable lockup allows it to be optimized for improved handling and power transfer for different traction conditions under turning, braking, and acceleration. Have they succeeded? I don't know.
The E-diff solves a problem that nobody had. I could see it being useful on all-wheel drive but the benefit to cost/complexity ratio is way too low for RWD.
Jag was probably thinking about future maintenance and replacement revenue.
The most brilliant engineering is almost always the simplest. i.e. Torsen.
This might help explain why Jaguar used an e-diff. Taken from an EVO magazine article.
“There are also developments at the back end of the drivetrain where a new, more rigid subframe supports a brand new diff featuring what Jaguar calls Active Differential Control, a system that uses a clutch pack controlled by a small, fast-acting electric motor to control the proportion of torque sent to each wheel. In normal, undemanding driving the system allows the car to run with a regular, open diff to the benefit of noise, efficiency and – since mechanical limited slip diffs can promote understeer in some circumstances – handling. But when things get more tasty the diff control can shunt torque across the axle, promoting better stability, better response and ultimately acting like a slippy diff so that if you’ve got the stability control off you can indulge in what Jaguar politely calls ‘controllable power-on oversteer’. Given the passion and enthusiasm of the team behind it what they really mean is, ‘We’ve built a bloody great drift car”
The following 4 users liked this post by Mufc:
