What did you do to your X300 today?
Old 10-23-2017, 05:16 AM
dfieldsend's Avatar
Gave mine a bath as well prior to the winter car cover arriving this week.
  #482
Old 10-23-2017, 04:38 PM
camprr's Avatar
Replaced the other 4 spark plugs. Correct gap for the 4.0 Supercharged X306 was 1.02mm We made it 1.05mm as we did not have a 0.02mm feeler guage.
Still waiting on the new rear brakes (green stuff) and the new polybush set, front anti-roll bar links and some other assorted stuff.
  #483
Old 10-25-2017, 08:59 PM
michaelmedina2005's Avatar
replaced external transmission wire harness
from trans thru round green seal
  #484
Old 10-26-2017, 04:52 PM
prepared,"powerflex",control arm
metal sleeve bushings for later installation,used 2000 grit pad,then 4000 grit,to make the surface even smoother,hopefully this will aid in no squeaks...
bottom...before,top....after,i used a c-clamp to hold sleeve...
  #485
Old 10-30-2017, 11:49 AM
greg21's Avatar
Default Front Springs
I replaced both destroyed front springs. It was awful good thing i didn't have to pay someone (the one on the left is the replacement, the opposite springs is burnt toast as well.)
  #486
Old 10-30-2017, 01:18 PM
labcoatguy's Avatar
Put it on a transporter going to Texas.
Now one of the few manual XJRs in the US will live there.
  #487
Old 11-01-2017, 04:34 AM
Mr happy's Avatar
Default My next job
Front springs and shocks ready to fit as soon as time allows.
  #488
Old 11-01-2017, 10:23 AM
Mr happy's Avatar
Default Old and new springs
Difference of approximately 32mm, hopefully correct ride height will be restored.will update when things completed.
  #489
Old 11-24-2017, 11:22 AM
touched up wheels with drill and polishing wheels,first,i used brown rouge,second,green rouge,final,white rouge...took 15 minutes
The following 2 users liked this post by michaelmedina2005:
al_roethlisberger (11-25-2017), Lady Penelope (11-24-2017)
  #490
Old 11-25-2017, 01:28 PM
al_roethlisberger's Avatar
Sorry to see it go, hopefully to a new home that appreciates it!
Didn't know it was for sale, too bad. The 5 speed would be fun.
  #491
Old 12-02-2017, 04:27 PM
Led Duck's Avatar
It went to me! It's been a great car, but it started having some surging issues (irrelevant of RPM) and there was a fuel smell in the cabin. So, I replaced the fuel pressure regulator, which eliminated the fuel smell in the cabin, but the surging remains. Hoping that the CTS that I ordered will fix that. I've also replaced one of the trunk struts and a friend helped me install X308 headlights, which now need adjusting!
  #492
Old 12-21-2017, 05:43 PM
aacpa15215's Avatar
I need to buy new springs for my 1996 VandenPlas (XJ6). Can you kindly share the source. Thanks
  #493
Old 12-21-2017, 10:57 PM
Mr happy's Avatar
Hi, yes, good old "British Parts UK" I have finished installing all the new stuff at the front of the car but it's still on axle stands at the mo as I'm doing some other little maintenance jobs, but hope to have her sitting on the ground in the new year, good luck with your project and happy Xmas to you.
  #494
Old 12-27-2017, 08:21 AM
dagny747's Avatar
Had the alternator and ac belts replaced, along with the valve cover gasket. I had tried to tighten the alternator belt myself which usually eliminates the squealing, but the nut was frozen even after I sprayed it and let it sit for awhile. So, as it was 20F yesterday, I gave up and let my local do it
  #495
Old 12-27-2017, 03:25 PM
Heh, must be "the season"
I've got my XJR up on ramps for the last week to replace my OEM alternator. I guess one can't complain too much that it lasted 21 years!
Of course if I'm replacing the alternator, might as well replace its belt, and since it is the rear belt, may as well replace the A/C compressor and SC belt too right?
But with the holidays and some intermittent rain and cold, it's been up on ramps waiting to be finished.
Good news is that the hard part is already done, which was figuring out how to get the alternator out, which turns out to be quite heavy to hold with one hand overhead!
The plan is to get it all reassembled by this weekend.
  #496
Old 12-31-2017, 01:22 PM
AL NZ's Avatar
New Year’s Eve - didn’t do much to the car.
Just a spot of wash, polish and wax, and changed the XJR’s sparking plugs from Champion RC12YC to a cooler 9YC at Andy’s suggestion. 4 of the 6 plugs needed gapping to .035" as they were much narrower out of the box. the other two were already right.
.(2 mins later)... well my photo post went well... guess that happens when you’re down under!
Attached Thumbnails What did you do to your X300 today?-62784c04-669c-4a94-a167-f70c986b0a8f.jpeg
The following 2 users liked this post by AL NZ:
al_roethlisberger (12-31-2017), Lady Penelope (12-31-2017)
  #497
Old 01-01-2018, 03:07 PM
AL NZ's Avatar
Summer here, Jaguar hiding in the shade
Attached Thumbnails What did you do to your X300 today?-730dd57f-af19-420c-8054-5736a2526adb.jpeg
  #498
Old 01-08-2018, 11:19 AM
aacpa15215's Avatar
Thanks. I will get this done some time before summer this year.
  #499
Old 01-08-2018, 08:51 PM
Scotlad's Avatar
Put new tires on today, bought at Tire Rack which is close to me. Went with 235-50-17 BF Goodrich Force C2 all season that were rated 2nd. in that category. Old tires from previous owner were 245-45-17, decided to go for a little more comfort.
  #500
Old 01-10-2018, 07:41 PM
cleaned up console and dash with detail brush and 303 aerospace conditioner
Quick Reply: What did you do to your X300 today?
