89 XJS full rich, fouling plugs
Old 12-01-2017, 01:26 PM
acauto's Avatar
Default 89 XJS full rich, fouling plugs
Hello, My 89 XJS (Marelli ignition) is running full rich, smokes badly especially cold start, plugs turn black immediately and then start to fuel foul. Any thoughts on fuel control?
Old 12-01-2017, 03:00 PM
brinny's Avatar
Ava?
Old 12-01-2017, 03:20 PM
Doug's Avatar
Received 10,876 Likes on 7,153 Posts
Excessive fuel pressure.
Coolant temp sensor skewed full cold
Injector harness shorted to ground making injectors stay open
Others will add to the 'could be' list
DD
Old 12-01-2017, 07:37 PM
Received 10,483 Likes on 6,922 Posts
TPS gone AWOL.
EFI Resistor pack multi plug needs a good clean.
Doug has spotted the rest in my head at this hour of the day, coffee 2 just started.
Old 12-01-2017, 08:07 PM
Jagboi64's Avatar
Received 3,145 Likes on 2,080 Posts
Major vacuum leak? Has the vacuum line to the ECU been damaged or come off? Vac line to the transmission modulator come off?
The XJS is a MAP (Manifold Air Pressure) management system, so it used vacuum as the load signal to the ECU. No vacuum = full throttle and maximum fuel demand.
Old 12-02-2017, 06:13 AM
Daim's Avatar
On both banks? Not that you simply lack sparks on one side...
Old 12-10-2017, 02:09 AM
orangeblossom's Avatar
Received 3,782 Likes on 2,617 Posts
Hi acauto
As mentioned by Grant
Resistor Pack plug and socket needs a good clean, or it can play havoc with the Injectors
Resistor Pack Plug and Socket near front Headlight Nacelle needs to be really clean or it can cause problems with the Injectors
Resistor Pack Plug also needs to be Clean
Old 12-10-2017, 08:07 PM
warrjon's Avatar
Does it still run rich once the car is warm?
My 89 Marelli also runs very rich only on cold start, once warm it is ok.
