Air Condioning Compressor Clutch Shaft Sheared Off...Question?
The A/C clutch locked up and the shaft (pictures) broke. The pulley spins freely and I was able to simply slide off the broken clutch and piece of shaft. Can I continue driving the car with this piece removed? Is the pulley securely on? I drive daily but will replace the entire compressor in spring. Can I wait? It's always something!
If you don't have an air pump, just cut the belt and all is fine. It is a rare thng for the shaft to snap. The co pressor is definately dead and scrap metal now. You won't be able to salvage any A6 parts.
Or just get a new compressor. Any single groove metric Harrisn A6 will fit. They don't cost much at all.
Received 10,954 Likes
From memory...
The pulley is a press-fit and has a snap-ring retainer as well.
Typically you need a puller to remove it after removing the snap-ring. I don't think you have to worry
When time comes to replace the compressor you need to determine if you have a "Superheat switch" type or the "HSLP" type. "High Side, Low Pressure"
DD
DD
rgp (12-20-2017)
rgp (12-20-2017)
orangeblossom
09-27-2015 11:32 AM
mrsambem
02-25-2014 02:44 PM
