Heated Front Windscreen - can it be retro fitted?
Hi All - Here's a question for you and any help or advice would be gratefully received.
Last year, I had a new front windscreen fitted to my 2003 XK8 4.2 due to a large crack in my old one. Unfortunately, the windscreen fitting company had only one in stock that day which was a heated one (mine was unheated). As I would have had to wait a few days for them to get one and mine needed changing urgently, I agreed for them to fit the heated one...leaving the connector wires attached but tucked away.
So my question is, can this heated screen be attached and used, and it so, what would I need to achieve this? ie. connectors, relays, switches, etc.?
If not, then no worries, it will just have to stay as it is. Thank you in advance.
Andrew
Andrew
You would need to have a look at the electrical guide for your car and see how the heated windshield is wired up. I would think at least a couple of relays and remember this will all be controlled by the computer - not a simple switch directly switching the relays.
Have you got the "def" button on your centre console? IIRC when you press this it turns the heated windscreen on and blows hot air at the screen - but its years since I've pressed mine.
andyzeg (02-12-2018)
I've been glad of the heated windscreen in my XK this last week. I also had one factory fitted in my 2005 XK8.
I think I recall correctly that the XK8 factory fit is switched on the console but is also setup to come on automatically and time out (the XK certainly is) which will be controlled through the ACC Module. This could get complicated to retrofit but no reason why you can't connect it as an independent switched feed only. I had one fitted like this in my XJ6 Series One in the early 1970's when the heated laminated screens were being developed. Definitely needs to go through a relay - it's taking a lot of power.
andyzeg (02-13-2018)
Received 2,398 Likes
All the heated laminated front screens from Pilkington (and formerly Triplex) have separate left and right elements.
When I had the test screen fitted in my XJ6, I had them wired and switched separately so I could run LH, RH or both. Jaguar have them through separate relays but then together on a single switch so this is not an option with the factory fit. It's either ON or OFF.
Received 2,263 Likes
Wrong forum.
Have a look at page 14 of this training guide - the page is specifically for the X103/105, but I think its the same for mine (previous year).
http://www.jagrepair.com/images/Intr...0TECH_2005.pdf
Wrong forum.
Short Answer is yes.
I took a set of relays and connector for the heater screen from a scrapped XJ.
Power for the heationg elements - via the relays is run from the Engine bay fuse box, I added the wires and fuses. Local earths points are also used.
To switch the relays take an ignition power from a nearby relay. The Earth is the control signal which needs to be routed from the body processer modul in the cabin.
Many thanks in advance.
That sounds great! However, and if it's not too much trouble...would you be able to go into a little more detail so that I can follow your instructions. I am usually quite capable with mechanicals...but something more "step by step" would be very much appreciated.
https://www.jaguarforums.com/forum/x...dshield-58222/
However the instructions from WhiteXKR (AKA the Jag Wrangler) for the instillation of the real gauge kit include a better way to run a control cable from the cabin to the engine bay than my Via the door method. (Which was also copied off WhiteXKR from his auto roof instructions)
RealGauge Installation - TheJagWrangler
Also I ran the cables across the engine bay by putting them under the shot panel. Which you need to remove to connect to the heated screeen anyway.
Hope That Helps.
andyzeg (02-16-2018)
I have a heated front windscreen in the front of my car. To be honest I really do not think its worth it.
When they say "heated front windscreen" you think its going to be just like the rear one. Its not. I put my rear on and you can see it working straight away but the front one is much more subtle than that. It only seems to gently heat the front screen.
If you stand at the front of the car looking towards the rear on the left side of the engine bay you have the corner compartment, the one covered by a plastic cover with a hole in it? If you take that off inside against the wing you will see a black plastic box. Just pull that off. Inside there will be just one relay towards the front of the car. Along side that are two slots for two more relays. Those are for the left and right sides of the heated windscreen.
frankc (02-17-2018)
Do you mean quicker defrosting or quicker clearing 'fogging' from glass when you first get in? I usually use the fan to demist. Now that is quick.
That's interesting. Perhaps mine has a fault then. I was disappointed with the performance of the front screen compared with the rear and I was told on a forum it was normal. But your saying its quicker?
Rear normally needs a few miles to clear condensation on an icy morning.
Hi Andrew,
this thread may be of some additional help for some more info...
https://www.jaguarforums.com/forum/x...dscreen-65098/
my Quartz XKR has an extra button on console and was standard equip on Canadian cars, but to find the right part may be a bit of a hunt... Im suprised that its was not standard equip in Scotland given the weather can "brisk".
Mine works quick to clear the glass of frost, when my wife and I went to the movies and came out to a frozen windscreen.
Andy
Andy
andyzeg (02-19-2018)
