trunk support brackets
I noticed today that my garage queen R has four plastic support under the gas tank to hold up the trunk floor ... my R bought new only has one (for the battery box) the holes are there .. but I can tell nothing was installed.
Now, I know why the trunk floor always fell down a bit -- Jaguar put a piece of foam on top of the spare to support the trunk floor.
What do most have ? It's a black plastic mount with one screw to the back bulkhead.
On mine, I have the space saver spare, but there's a metal threaded piece that threads down through one of the lug holes and into the assembly underneath (a foam piece that holds the jack). The top of this piece has a 90 degree bend and a flattened top, so it threads down to a point where it would give support underneath the floor in the center.
I have the 4 plastic supports under the gastank, behind the liner, and the above mentioned angled threaded piece through the (full) spare.
The good thing of that one is, that it is kind of adjustable in height, and with a bit of fiddling, perfectly supports the trunk floor in the center.
But I have also seen the foam squares under the floor for both full spars and space savers.
The following 2 users liked this post by motorcarman:
cliveb (02-28-2018),
ericjansen (02-28-2018)
Maxmaxemus
04-22-2013 09:18 PM
