Is this ZF pan seal / gasket correct
Old 03-05-2018, 10:40 AM
‘Oleguy's Avatar
Default Is this ZF pan seal / gasket correct
I purchased a new filter/pan off of EBay with oil and the pan has an o-ring type seal installed. Is this correct for my 2008 XKR Convertible?
Old 03-05-2018, 11:18 AM
Sean W's Avatar
Received 4,246 Likes on 2,375 Posts
No luck on searching the pan # and the gasket number is all over the place with some sites saying it fits and some saying it doesn't.
Your transmission is ZF6HP26. If your eBay listing indicated it's for that transmission, you should be good to go.
Old 03-05-2018, 12:36 PM
JackJohn's Avatar
That looks like the seal that was on the pan I bought and it worked correctly.
Old 03-05-2018, 01:45 PM
Sean W's Avatar
Yep sorry. If the question was is this the right type of seal used on the ZF pan, then yes it is. I read the question as "did I buy the right pan/ gasket".
Old 03-05-2018, 02:37 PM
‘Oleguy's Avatar
Thank you gentlemen for your reply’s. I had not seen a trans pan with an imbedded o ring seal before, always a gasket.
When I emailed seller he said if you want a gasket with the pan order ‘this one’ and gave me another listing.
I’ll use what I have. I was bit sckeptical so I also ordered a 26$ special order pan gasket from AUTOZONE.
It sounds as though I don’t need it.
Old 03-05-2018, 03:05 PM
Sean W's Avatar
Correct Oleguy. No flat cork or paper gasket is used on the ZF transmission.
Old 03-05-2018, 04:26 PM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Did you buy the kit with fluid/pan/filter? I would be most concerned about the fluid as I read there is plenty of counterfeit ZF fluid on the market.
Old 03-05-2018, 06:27 PM
‘Oleguy's Avatar
Yes I did buy the kit. Oil and pan. The meclotronic seal was seperate
Old 03-05-2018, 07:09 PM
The seal came with the two kits I bought.
Andrew Fitch
11-20-2016 09:02 AM
hoya_loya
05-27-2015 08:50 PM
m1eckler
02-27-2015 07:20 PM
BStopek
03-03-2013 11:30 AM
dreamcar
07-19-2010 11:01 AM
Quick Reply: Is this ZF pan seal / gasket correct
