How much room in lower grill?
Old 02-21-2018, 09:28 PM
Twiztidunreal's Avatar
Default How much room in lower grill?
How much room is there behind the lower grill on a 2010 XF supercharged? I am looking so I can size a front mount heat exchanger. I was looking to place it below the front support, but don't know how long or how tall I can go. I was looking at one that is 30"x3"x6" and a dual pass, so both connections are on the same end, as the pump.
Anyone have any experience with the room under there? any pics or measurements?
Old 02-22-2018, 04:20 PM
Akwarr's Avatar
Question? What are you going to do with the current intake design? It does not support an external intercooler
Old 02-22-2018, 06:20 PM
i was going to add it inline after the current set up. Basically the heat exchanger system will stay set up as is, except replace the factory pump with the Bosch 010 and add the cooler after the pump, before it is pumped into the top mounts.
So hot coolant would go from the top mounts, down to the factory cooler, out the pump on the end of the cooler, into the aftermarket cooler, then cool coolant back up to top mounts, and so on.
Old 02-23-2018, 12:58 PM
Akwarr's Avatar
my head is spinning from reading that. LOL. there isnt much room but should be enough for what your planning to do
Old 02-23-2018, 03:10 PM
OzXFR's Avatar
Received 3,217 Likes on 2,372 Posts
Just take the front bumper right off and check everything yourself.
It's not that hard to do, just lots of bolts and screws and a couple of electrical plugs to disconnect, I did it several times on both my XFS and XFR.
Old 03-06-2018, 11:34 PM
This is what I ended up ordering. Dual pass and core is 24"x3.5"x3.5". Even comes with a spot to add a temp sensor if you like. We will see how I can get this thing mounted when it gets here, hopefully next week.
Old 03-12-2018, 09:15 PM
I was aiming for the lower grill, but it might get more flow in the top grill
IansJagXF
02-21-2018 10:08 PM
Quick Reply: How much room in lower grill?
