Old 03-19-2018, 04:02 AM
chris-jag's Avatar
why is it that Carnival Kid's jag looks:
1. Just out of the showroom
2. Like it goes to the gym twice a week
I've got a long way to catch up :=)
cliveb (03-19-2018)
  #2742
Old 03-19-2018, 04:13 AM
Daim's Avatar
If your car looks presentable, then you've already overtaken me
ericjansen (03-19-2018)
  #2743
Old 03-19-2018, 10:52 AM
Carnival Kid's Avatar
Received 1,010 Likes on 613 Posts
why is it that Carnival Kid's jag looks: 1. Just out of the showroom 2. Like it goes to the gym twice a week
Thank you Chris, praise indeed, although I have to admit I cannot claim veneration for the condition as i have only owned the car for just over two months, the praise should go to the previous owner for caring for it so well over 17 years and 70,000 miles. I'm just its new caretaker fixing the mechanical things.
  #2744
Old 03-19-2018, 11:26 AM
Daim's Avatar
So, fitted my new (to me) belt tensioner, after exchanging the plastic pulley for a metal one (even though the plastic had a new bearing fitted).
Found out, that my nasty cold start squeal is the bearing from the AC compressor. So that is on the list to change.
Also had the first delivery of parts for my suspension alteration. Especially some Moog ARB endlinks... Went 'Problem Solver' instead of factory, as the last original Jaguar ARB endlink only lasted 2 years...
  #2745
Old 03-19-2018, 12:03 PM
Lady Penelope's Avatar
Daim ,
Check for the correct model number . Depending on your installation you may be able to remove the clutch without disturbing the compressor and it's lines
https://www.shopcenturyautoair.com/s...ing_BG405.html
The video is for a Denso 10PA - 15C and I believe yours is a 17C as a Jaguar # MCA7300AE
If you want to go ahead and overhaul the compressor other video and parts are on that site .
https://www.shopcenturyautoair.com/s...mpressors.html
  #2746
Old 03-19-2018, 12:39 PM
Daim's Avatar
@Lady Penelope
Century is are at place. Bought my Harrison A6 compressor parts from there to get it oil tight again (see XJ-S section).
Mine is a very, very early X308. So I think it has the replacable bearing setup. So that should be no issue.
Thanks for the links
  #2747
Old 03-19-2018, 07:06 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
There's a very good exhaust & suspension shop locally, I plan on going in tomorrow morning having them look @ my hangers & grease the u-joints while under there. Also getting a quote on installing the remote exhaust cut-outs (sinister chuckle) lol.
  #2748
Old 03-19-2018, 07:32 PM
ericjansen's Avatar
Received 1,353 Likes on 927 Posts
One word of advice on the location of the cutouts, this my own experience, and a Utah friend I just helped.
If you install them after the cat, before the center muffler, they will be loud, very loud.
My Utah friend just did that, now he drives around with the cutouts mostly closed, or just cracked open, as it is tooooo loud for longer than just that fun moment.
If you install them after the center muffler, it will will give a nice rumble, but never be too loud, maybe a tat too low.
Mounted there, you will not need an intermittent position, just full closed or full open.
There is also a significant difference in temperature between the 2 locations, plus some fuel lines.
Not saying where to put hem, to each his own, just that you know.
King Charles (03-19-2018)
  #2749
Old 03-19-2018, 08:02 PM
Yeah I'm going for the nice rumble, not looking for the Dukes Of Hazzard effect lol.
  #2750
Old 03-20-2018, 12:43 PM
Zues's Avatar
Daim, I was just about to order those endlinks but read that they do not come with the bushings. Would you happen to have a model number? Also a note on the compressor. Watch out for the spacer/washer on the spline. Once the new bearing is installed make sure the clutch and compression plate spin separately from each other freely.
  #2751
Old 03-20-2018, 12:52 PM
Daim's Avatar
The blue PU bushing halves were included.
BUT if your question was refering to the Moog part number for the entire endlink, it is K750225. That is as a kit with the blue PU bushing halves, the link and co.
And as Sean has yet again basically said I am a very unthankful person: A VERY warm and friendly thank you for the information regarding the bearing. I am VERY grateful for little tips regarding future jobs to do. Idon'to always say thank you, because it is a standard thing for me, that someone doesn't need to say thank you but is still thankful. So, just to make it clear: thank you again!
Sean B (03-20-2018)
  #2752
Old 03-20-2018, 01:01 PM
Sean B's Avatar
Received 1,362 Likes on 1,071 Posts
I think he asked for a part# and offered some sage advice on the bearing job - thanks goes a long way - just saying mate
  #2753
Old 03-20-2018, 01:26 PM
Daim's Avatar
Bit hard to thank someone when using the app, mate But yes, I am a very unthankful, rude, obnoxious person. Not everyone was born with a halo
Oh, and I understand the question as 'do you have the parts number for the bushes'...
But I correct my post, made sure that my intension was not to be a rude person and I express my thankfulness to a high degree.
Thank you for your tip and that a thank you never goes as miss. Especially since I don't see the need to express a thanks everytime, as I am always grateful for help...
  #2754
Old 03-20-2018, 02:09 PM
Zues's Avatar
Cheers to you both.
Jhartz (03-21-2018)
  #2755
Old 03-21-2018, 03:09 AM
Update :
Had the car on the lift everything in the rear looked snug & not to be knocking. Not sure where my noise is coming from. Noticed the exhaust system has been patched & banged around a bit, starting to leak. So I'm on the hunt for those components now if anyone has any sources.
  #2756
Old 03-21-2018, 10:08 AM
Takeo's Avatar
Received 1,949 Likes on 870 Posts
Bought a pair of Bilstein new front shock absorbers. From Berkshire Jag components.
  #2757
Old 03-21-2018, 05:25 PM
Also how does one access the U-joints or zerks on these to lube them ?!
Edit
Productive day today, washer nozzle replaced, I can finally get the pollen off my windshield lol.
Undercarriage inspected on lift, caught an exhaust leak forming.
Since I'm a frequent flyer my paint shop quoted me $250 to respray my front bumper, going in Monday.
Cruise control switch installed & fully illuminated.
  #2758
Old 03-22-2018, 05:38 AM
Robman25's Avatar
Went on a track day last weekend and a) removed a large amount of marbles from the all the tyres on Tuesday, also noticed a couple of stone chips on the bonnet.
Decided to apply some clear vinyl, yeah I know what I’m doing.
So after I come back from our trip down south the car goes in to have the bonnet repainted where I managed to rip off about a square foot of top coat to say I was rather mortified would be an understatement SWMBO seemed extremely calm about it.
  #2759
Old 03-22-2018, 10:02 AM
Jhartz's Avatar
When it is on the lift, the fittings are easy to access. Me, I had to lift it on a jack and crawl under it; next year, let the Indy do it while changing the fuel filter.
  #2760
Old 03-22-2018, 08:37 PM
My trip/odometer switch has arrived, I plan to install tonight & will then have all my interior lights except the passenger door switch pack lights functioning ! I have the door switch bulbs on hand, just waiting to tackle all 3 @ once, likely when I do the door catch plate fix.
