Transfer case replacement
Old 03-16-2018, 03:39 PM
Julianj08's Avatar
Default Transfer case replacement
Just bought a 05 x type with a bad transfer case already removed by the previous owner.. have since bought a replacement and ready to reibstall... QUESTION: on a scale of 1 to 5 with 5 being the best I consider myself as having a 2.5 or 3.0 when it comes to mechanical skills.... I am thinking of trying yo put in the transfer case myself... do you think I will be in over my head??
THANKS
Old 03-16-2018, 04:48 PM
Dell Gailey's Avatar
Old 03-17-2018, 05:50 AM
astromorg's Avatar
Here are some more useful links, although they do suffer from the photobucket ban on free photo sharing. I believe there are workarounds? Anyone know?
How to replace a Transfer Box
Transfer Box removal, rebuild and replacement
Old 03-17-2018, 06:24 PM
Julianj08's Avatar
Default Transfer case reinstall
As I mentioned I bought a 05 x ype with the transfer case already taken out... have bought a new used one and ready to attempt to put it back in myself... can someone look at the attached pictures and tell me what parts these are and where they should go... thanks
Old 03-17-2018, 06:50 PM
Old 03-17-2018, 07:26 PM
Julianj08's Avatar
None of the parts pictured are in the diagram...
Old 03-18-2018, 06:26 AM
x_type_lpg's Avatar
you need a copy of jtis, the workshop manual shows how to take the transfer box out and has pictures of the main parts. the long shaft goes into the box but should not have been removed, the smaller part goes on the end of the shaft and the drive shaft goes into the big end.
Old 03-18-2018, 06:47 AM
Julianj08's Avatar
Since the long shaft has been removed what are my options?
Old 03-18-2018, 08:22 AM
Received 8,194 Likes on 4,941 Posts
If the circlip on the end of the shaft has been removed, the seals are likely OK.
It is the wire retaining clip on the end that damages the seals.
bob
Old 03-18-2018, 09:36 AM
Julianj08's Avatar
Assume the worst case.... whst should I do..
Old 03-18-2018, 12:56 PM
astromorg's Avatar
Sorry, but to be brutal, noting from your OP
.... on a scale of 1 to 5 with 5 being the best I consider myself as having a 2.5 or 3.0 when it comes to mechanical skills.... I am thinking of trying to put in the transfer case myself... do you think I will be in over my head?......
get another transfer box!!
Replacing the seal that only might have been damaged if that shaft was removed with its wire clip in place at the splined end, is a major engineering job requiring the t'box to be stripped and rebuilt. Not one for the faint hearted!!
You should be able to get a partial view of the seals inside the box, looking in the left hand side to see if there's any obvious damage.
Good luck!
Old 03-18-2018, 01:49 PM
Julianj08's Avatar
Great news!!!! The clips were taken out before the shafts were removed from the tc....
motorcarman (03-18-2018)
Old 03-20-2018, 05:49 PM
dh53's Avatar
The bottom picture is the "roll restrictor". It bolts to the front subframe and to the bracket bolted onto the transmission/transfer case right next to the driveshaft. Without it you will notice it doesn't take much force to rotate the engine and transmission.
Old 03-23-2018, 11:57 AM
Julianj08's Avatar
Default TC oil
Plan to drain and refill transfer case... was told to use Royal Purple but can't find it... can i use any TC oil or does it have to be a specific brand and how much does it take to refill?? Thanks
Old 03-23-2018, 11:12 PM
Old 03-24-2018, 04:38 PM
As for amount, please do a forum search (I even have a couple w/pics) on changing and amounts. It depends on process of removal, how much you remove, how much it holds for full, and excess blowout if over filling.
Muamin
02-10-2016 08:36 AM
Maxmaxemus
04-22-2013 09:18 PM
tarheel72
11-06-2011 07:56 AM
2Mchite
11-17-2010 10:48 PM
John Mac
11-29-2008 07:21 PM
Quick Reply: Transfer case replacement
