XJ40 wheels on S3
Old 04-06-2018, 02:39 PM
Roger Mabry's Avatar
Default XJ40 wheels on S3
My question is really for LnrB:
Your wheels are similar to mine, do the center caps fits on your car with the front grease caps in place? What size tires are you using?
I am in the process of collecting S3 front hubs and the related parts to change mine to the later stuff.. want to get rid of the now "required" spacers that allow
the center caps to fit on the front.
Old picture of the car before EFI and lowering, but it shows the wheel.
Old 04-06-2018, 03:26 PM
Received 9,241 Likes on 5,400 Posts
Not without 3/8 inch spacers.
https://www.jaguarforums.com/forum/x...2/#post1058682
What size tires are you using?...
215/60/15 General Altimax HP
I've put so much effort into the front suspension of this car, and I like these chromed teardrop wheels so much, I'll continue to use spacers until I get into trouble with them..... which I don't expect to ever happen.
Old 04-06-2018, 03:44 PM
studentper's Avatar
Question: Do the spacers change the driving dynamic at all? I have an 87 xj6 that had the teardrop wheels on it without the spacers and the front hub is exposed.
Nix is a beautiful beast, btw.
LnrB (04-06-2018)
Old 04-06-2018, 04:03 PM
Jose's Avatar
Received 2,445 Likes on 1,840 Posts
I have Teardrops too and the hubcaps won't fit without spacers. I glued them to the hub because if you remove the wheel they fall off and then getting them centered behind the wheel is a pain, so I glued them centered.
there is no change in the steering dynamics, I use fat tires, 265/60/15, it corners like a tank.
LnrB (04-06-2018)
Old 04-06-2018, 04:30 PM
Nix thanks you for your kind comment.
When I was growing up on the farm, the worst offense one could do was run without bearing dust cups, as naked bearings might not last the day. One could be nailed to the side of the barn for such negligence! We put far too much money, time and effort into refurbing the front suspension to throw it away for lack of a dust cup.
These spacers don't change handling in the Slightest! I don't have the loosey goosey problem Jose mentions though, because husband found some hub-centric spacers, billet cut, that fit like the proverbial glove.
These come in several thicknesses and are Quantum superior to the cheap-bleep things they replaced, which rattled, weren't balanced, and just plain looked Terrible!
Jose (04-06-2018)
Old 04-06-2018, 04:47 PM
Jose's Avatar
I want a pair Elinor!! where do I order them??
Old 04-06-2018, 08:03 PM
Thanks for all the replies, saved me a lot of work and money. I will not change the front hubs to S3, I am happy with the current ones and braking.
Will go ahead and order the hub centric spacers, current ones are 5/32 inch thick but are lug centric and are hard to get into exact spots for good balancing. I do have longer lug nuts to get the proper number of threads covered. Are yours long enough???
Old 04-06-2018, 08:24 PM
Summit Racing, item# WSG5L375
Billet Specialties Wheel Spacers; $25.97ea.
Or, one can have the flanged hub-centric spacers (which may or may not fit out of the box),
for all XJ and XK series from 69-03 direct from factory:
http://www.ezaccessory.com/Billet_Hu...120-10j-lo.htm
The 3rd Rule of Acquisition definitely apples here:
"Never Pay More Than You Have To"
I thought the studs were plenty long (Many more threads by twice than the 3/4" spacers on the car when we got it!) but husband made me change to longer ones anyway.
EDIT
: Nuts are stock length alloy nuts. You may find you need to "finesse" your longer lug nuts into the smaller bolt holes in these spacers, or revert to standard length lug nuts.
Jose (04-06-2018)
Old 04-08-2018, 11:28 AM
alynmurray's Avatar
Weeelll.. I must have gotten lucky when I changed wheels / tires from 15 inch chromed Kents and 215 70 15 tires to a 16 inch wheel (20 spokes) 225 60 16 tires, as found on a 1996 XJ6.
Everything fit perfectly no spacers and the centers are just little caps with the Growler on them - the wheels have center sections that are a part of the wheel itself., just the little cap on the end (thanks David Boger) absolutely zero issues. Actually got lucky twice,..because now that I am into swapping to a ventilated rear outboard brake system - the larger outboard caliper might not have fit into the old 15 inch wheel. In fact the calipers on solid rear discs (as opposed to ventilated) are quite a bit smaller - perhaps to fit the smaller 15 inch wheels. The calipers on the vented rotors are "beefier" needing more room in the back of the wheel.
Attached Thumbnails XJ40 wheels on S3-1%7E1428199053.jpg   XJ40 wheels on S3-20141108_130443.jpg   XJ40 wheels on S3-20141108_145743b.jpg
bpwu (08-18-2018)
Old 04-08-2018, 11:47 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
"Nailed his/her hide to the wall". Very expressive!!!
Decades ago, I was walkig down the street, in El Paso, I think. I happened to notice a "not that old" car at the curb. Sans hub cap. Wowee, no dust cap either ! and, worse, no sign of an outter bearing.
Only the nut and tanged washer keeping the hub and wheel on the axle!!!!!
Carl
Old 04-08-2018, 12:56 PM
alynmurray
It is not the wheels that do not fit but the center cap that is just a little rounded outward in the middle. Your wheels are a different that gives room for the grease cap.
NICE!
Old 04-08-2018, 11:52 PM
Very nice rims, Alyn, very nice indeed.
However, Roger's and mine are different in having hubcaps like the old days. These hubcaps make spacers necessary to use our rims.
Roger Mabry (04-09-2018)
Old 04-10-2018, 04:34 PM
My hub centric spacers arrived today, from EZ Accessory, but my story is different from LnrB's. They fit the wheel center hub perfectly... could not ask for a better fit.
But they do not go onto the front hubs all way.. they hang up on the second set of ridges on the inside or about 10 mm from resting against the hub face. I measured the hub OD
at the most inner position, 96 cm, or approximately 2 7/8". Will have to enlarge them both by a bunch.. will take more measurements. I do have Dykem fluid left over from another non fitting part in the past.
After rethinking this whole thing, these adapters would only work as spacers that would fit tight onto the front hubs if the whole "hub centric" piece was removed. Will think
about it overnight and decide whether to cut off the hubs or just not use them at all.. I tried grinding the inside down to figure out that the needed goal size was not achievable.
I am just as unhappy (maybe MORE) than Elinor's Husband. Their ad does say they fit the rears??? But that is not my application. This was a waste of time and money...
Old 04-11-2018, 08:38 AM
PLan now is to enlarge the center of the spacers so they fit tight on the front hubs.. they will be better than the old ones that were very loose and took tape/adhesive to stay in
place. I have them now and do not need them on the rear, so will modify them to fit onto the front hubs...
I will cut a notch into them for the grease fitting the lubes the front hubs if that does not clear when finally fitted.
Old 04-11-2018, 10:16 AM
JagCad's Avatar
Or, merely remove the Zerk and use a flat Allen to close the hole.
Oddment anyway, is it really a good way to "pack the bearings" ?
But, if desired, merely remove the Allen, replace a Zerk and pump away!!!
Eliminates cutting a wheel and the fiddling in mounting the wheel to align the slot and the Zerk!!!
O Lottsa ways to skin.....
Carl
Old 04-16-2018, 03:57 PM
Finished up the two spacers, used a carbide tip and enlarged the center to equal the outside OD of the "hub" for the wheel fit... plus I had to enlarge the holes for the much longer lugs
used by my wheels...now these are "hub" centric but fit tight and are a little thicker than my old ones. Zerk fitting fits fine now... I replaced the now too short shock mounting bolts and there are threads sticking out of the nuts now.
Just waiting for the new Boge shocks to arrive later today.. will then finish up the drivers side with the new 1/2 bushings..
LnrB (04-16-2018)
Old 04-16-2018, 06:49 PM
I'm glad you've prevailed, Roger.
Husband was suspicious when the ad said they "fit Jaguars, but some modifications may be needed."
Mine fit tight now too, with Much more contact between wheel and hub than with the Cheapies.
Old 04-17-2018, 07:19 PM
All done... 1/2 spacers in both sides with the proper length bolts. New front shocks (Boge) and they make a big difference in the ride.
I am happy with the new lowered stance...just have to re-adjust the headlights again.
LnrB (04-17-2018)
Old 04-18-2018, 09:35 AM
JagCad's Avatar
All's well that ends well !!!
Dun good!!
Those non hub centric "spacers" scare me. Not much if any better than a stack of washers., BRRRR!
Carl
Old 04-19-2018, 03:17 PM
New spacers fit very tight on the hubs and the longer lug nuts go through the holes. It drives much smoother now at higher speeds (no wheel shakes or vibrations).
The new shocks are MUCH better and the ride over bumps and RR tracks is very smooth and quiet. The best two mods I have done for the car.
Quick Reply: XJ40 wheels on S3
